  • July 06, 2025, 10:45:15 PM
Author Topic: Cracks in fuselage.  (Read 2271 times)
Offline Charles Carter
  • Flying Control Line Stunt
Cracks in fuselage.
« on: December 23, 2014, 11:12:48 AM »
Should I do something about the cracks in the fuselage sides in front of the leading edge of the wing and behind the trailing edge of the wing? What I have done is applied some thin CA into the cracks.
Charles Carter
Re: Cracks in fuselage.
« Reply #1 on: December 23, 2014, 11:25:15 AM »
That depends on how big they are, whether they're just in the paint or if they extend into the wood, and whether they're there from crash damage or fatigue.
For the most part, putting CA in the cracks will probably slow down the process but not stop it.
There's probably fixes that you could do, but I'd be tempted to just build another plane, and maybe try to figure out why the cracks so you can keep it from happening on the new one.
« Reply #2 on: December 23, 2014, 05:53:06 PM »
Stress cracks were common fare in the old days before we used epoxy for wing/fuse joints.  Adding a doubler on the inside with epoxy may be needed to fix yours.  These days I use epoxy on the inside and cement with carbon tissue outside to help hold the fillets down.  Dope will pull up right off epoxy in this joint.  Fixing these cracks are tough once oil has gotten in.  Cya is about as good as anything because it can penetrate and encapsulate the oil better than most anything else.
Offline Matt Colan
« Reply #3 on: December 23, 2014, 11:06:06 PM »
I had an issue with stress cracks a few years ago with my Trivial Pursuit. Here is the thread detailing what was going on and how I went to fix it. There's a lot of good info in this thread:
http://stunthanger.com/smf/index.php/topic,22546.0.html
« Reply #4 on: December 24, 2014, 12:21:10 PM »
My Sterling Yak-9, built last winter is doing the same thing. I think the epoxy laminated fuse is its saviour so far, but I'm afraid it's facing early retirement. I've been blaming the hairline fractures on the Fox 35 and filling them with CA. One good bonk and it might turn into a hundred piece puzzle.
Rusty
« Reply #5 on: December 24, 2014, 12:41:33 PM »
Hi Charles,
Built up fuselage or profile?  What engine?  What type of fillets did you use?
BIG Bear
RNMM/AMM
« Reply #6 on: December 24, 2014, 12:45:04 PM »
Rusty
Hi Rusty,
99.9% of the time, cracks like those are not structural on a profile like the Yak-9.  You can fly for years with them.  Filling them with CA is a good idea.  What type of fillet did you use?
BIG Bear
RNMM/AMM
« Reply #7 on: December 24, 2014, 02:00:50 PM »
Hi Rusty,
BIG Bear
RNMM/AMM
Hi Bill, Merry Christmas.
I made the filets with a thick mix of glass microballoons and 60 minute epoxy. There ain't much holding that wing on from the bottom, so I glued an inch wide strip of basswood from under the air scoop and jammed it in between the wing and fuse at the front.
Rusty
Offline kenneth cook
« Reply #8 on: December 24, 2014, 02:08:51 PM »
             A very common problem with the Yak due to the fuse just sitting on top of the wing. The only portion that wraps over the leading edge is only about 3/4" long. Just keep gluing it. I've ground out the fillet and stuffed in some milled fiberglass with heated epoxy with good results. Another option is to stake the small piece that wraps over the leading edge. From the bottom up drill a hole for a 1/8" dowel about 2" long and insert it through the fuse and through the leading edge back into the fuse. Ken
« Reply #9 on: December 24, 2014, 02:59:18 PM »
The title "root folder" raises one's eyebrows.
« Reply #10 on: December 24, 2014, 04:04:11 PM »
Slight cracks were the norm for me when I was younger using a Fox .35 in a profile. ;D
BIG Bear
RNMM/AMM
Offline Keith Miller
« Reply #11 on: December 24, 2014, 06:16:19 PM »
Hi Charles!
Y'know that white Tutor II that I have?  Its front end has had many cracks filled just the way you describe and she's holding together really well!  It looks like crap, but you've seen how it's flown :)
Offline Sean McEntee
« Reply #12 on: December 25, 2014, 02:39:49 PM »
Rusty
Rusty thanks for sharing.  Im almost to final assembily on my T-6, and it too has almost no support under the wing.  Thanks for the info
Offline Carl Cisneros
« Reply #13 on: December 25, 2014, 07:14:44 PM »
Rusty and Ken
Iwill incorporate both of your suggestions on my Yak when I start building it in abou ta month.
Carl R Cisneros, Dist IV
Control Line RB
« Reply #14 on: December 26, 2014, 11:08:39 PM »
Rusty and Ken
I will incorporate both of your suggestions on my Yak when I start building it in about a month.
Carl, when you do get it on the table, if you start a build thread we can talk about it without hijacking the original topic. I know of several things that might be of interest to you. Actually I learned most of them from Ken. The Sterling Yak and its twin brother F-51 Mustang have some important similarities
Rusty
