Brett goes on about this time after time.....
I cannot say this enough : Weight has nothing to do with it.
We live in an age where engine power is almost limitless - these designs fly better with more power and more weight.
My original '51 .61 was 53 oz - The '68 .61 was 54 oz
Of course if your going to build it with the intention of a Veco .29 then I wouldnt go much higher than 45..
The key really is the performance of the engine.. the airframe / wing will lift more weight with ease and in almost everycase it will perform better as a result.
See the Fancher/Ruffy conversation
I would take issue with that to a point, I had many Noblers and flew even many more, Mine at 43 ounces 1 to 1 turned flat and hard, I have a friend who had one at 38 ounces that turned pretty tight.
I have also flown ones at over 50 ounces that dropped in the corners, and stalled at points with powerful motors.
Now these were stock Noblers, not expanded as many I see today are.
Also the BIG problem with adjustable elevator horns..besides they break or slip often is... You will have to make teh control throws even quicker when you add elevator, to try to take away flap travel. YOu are better off either trimming the flaps down if TOO light, which is what Brett was eluding to, or even better, It is much better to make the flap horn adjustable, rather than the elevator, that way if you need to slow the flaps, you can slide the elevator are upwards.
