  • July 19, 2025, 01:09:50 PM
Author Topic: Copyrights and this site.  (Read 16421 times)
Online RC Storick
« on: February 20, 2007, 10:39:46 PM »
The onus is on you. Stunt Hangar makes every attempt to oversee that no copyrighted material is on here. When you joined this site, you signed an electronic agreement stating that you are responsible for your posts and indemnifies the Liability of Stunt Hangar.
You can best bet that if it was published in MA,FM or some other large magazine it has been copyrighted. If it's not your work please don't post it here.
Copyright Registration
In general, copyright registration is a legal formality intended to make a public record of the basic facts of a particular copyright. However, registration is not a condition of copyright protection. Even though registration is not a requirement for protection, the copyright law provides several inducements or advantages to encourage copyright owners to make registration. Among these advantages are the following:
Registration establishes a public record of the copyright claim.
Before an infringement suit may be filed in court, registration is necessary for works of U.S. origin.
If made before or within 5 years of publication, registration will establish prima facie evidence in court of the validity of the copyright and of the facts stated in the certificate.
If registration is made within 3 months after publication of the work or prior to an infringement of the work, statutory damages and attorney's fees will be available to the copyright owner in court actions. Otherwise, only an award of actual damages and profits is available to the copyright owner.
Registration allows the owner of the copyright to record the registration with the U. S. Customs Service for protection against the importation of infringing copies. For additional information, go to the U.S. Customs and Border Protection website at www.cbp.gov/xp/cgov/import. Click on “Intellectual Property Rights.”
Registration may be made at any time within the life of the copyright. Unlike the law before 1978, when a work has been registered in unpublished form, it is not necessary to make another registration when the work becomes published, although the copyright owner may register the published edition, if desired.
Notice of Copyright
The use of a copyright notice is no longer required under U.S. law, although it is often beneficial. Because prior law did contain such a requirement, however, the use of notice is still relevant to the copyright status of older works.
Notice was required under the 1976 Copyright Act. This requirement was eliminated when the United States adhered to the Berne Convention, effective March 1, 1989. Although works published without notice before that date could have entered the public domain in the United States, the Uruguay Round Agreements Act (URAA) restores copyright in certain foreign works originally published without notice. For further information about copyright amendments in the URAA, request Circular 38b.
The Copyright Office does not take a position on whether copies of works first published with notice before March 1, 1989, which are distributed on or after March 1, 1989, must bear the copyright notice.
Use of the notice may be important because it informs the public that the work is protected by copyright, identifies the copyright owner, and shows the year of first publication. Furthermore, in the event that a work is infringed, if a proper notice of copyright appears on the published copy or copies to which a defendant in a copyright infringement suit had access, then no weight shall be given to such a defendant’s interposition of a defense based on innocent infringement in mitigation of actual or statutory damages, except as provided in section 504(c)(2) of the copyright law. Innocent infringement occurs when the infringer did not realize that the work was protected.
The use of the copyright notice is the responsibility of the copyright owner
Registration Procedures
Original Registration
To register a work, send the following three elements in the same envelope or package to:
Library of Congress
Copyright Office
101 Independence Avenue, SE
Washington, DC 20559-6000
A properly completed application form.
A nonrefundable filing fee* for each application.
The deposit requirements vary in particular situations. The general requirements follow. Also note the information under “Special Deposit Requirements.”
If the work was first published in the United States on or after January 1, 1978, two complete copies or phonorecords of the best edition.
If the work was first published in the United States before January 1, 1978, two complete copies or phonorecords of the work as first published.
If the work was first published outside the United States, one complete copy or phonorecord of the work as first published.
If sending multiple works, all applications, deposits, and fees should be sent in the same package. If possible, applications should be attached to the appropriate deposit. Whenever possible, number each package (e.g., 1 of 3, 2 of 4) to facilitate processing.
Online RC Storick
Re: Copyrights and this site.
« Reply #1 on: February 21, 2007, 06:46:43 AM »
A reminder of what you agreed to.
Your Real First and Last Name are your user name. You can change the Display name once you are logged in. Only Admin can see your information. This is Mandatory!
You agree, through your use of this forum, that you will not post any material which is false, defamatory, inaccurate, abusive, vulgar, hateful, harassing, obscene, profane, sexually oriented, threatening, invasive of a person's privacy, adult material, or otherwise in violation of any International or United States Federal law. You also agree not to post any copyrighted material unless you own the copyright or you have written consent from the owner of the copyrighted material. Spam, flooding, advertisements, chain letters, pyramid schemes, and solicitations are also forbidden on this forum.
Note that it is impossible for the staff or the owners of this forum to confirm the validity of posts. Please remember that we do not actively monitor the posted messages, and as such, are not responsible for the content contained within. We do not warrant the accuracy, completeness, or usefulness of any information presented. The posted messages express the views of the author, and not necessarily the views of this forum, its staff, its subsidiaries, or this forum's owner. Anyone who feels that a posted message is objectionable is encouraged to notify an administrator or moderator of this forum immediately. The staff and the owner of this forum reserve the right to remove objectionable content, within a reasonable time frame, if they determine that removal is necessary. This is a manual process, however, please realize that they may not be able to remove or edit particular messages immediately. This policy applies to member profile information as well.
You remain solely responsible for the content of your posted messages. Furthermore, you agree to indemnify and hold harmless the owners of this forum, any related websites to this forum, its staff, and its subsidiaries. The owners of this forum also reserve the right to reveal your identity (or any other related information collected on this service) in the event of a formal complaint or legal action arising from any situation caused by your use of this forum. Stunt Hangar from time to time may use your posts in our magazine for a column called the BEST OF THE WEB.
You have the ability, as you register, to choose your user name. We advise that you use Your Real First and Last Name. With this user account you are about to register, you agree to never give your password out to another person except an administrator, for your protection and for validity reasons. You also agree to NEVER use another person's account for any reason.  We also HIGHLY recommend you use a complex and unique password for your account, to prevent account theft.
After you register and login to this forum, you will be able to fill out a detailed profile. It is your responsibility to present clean and accurate information. Any information the forum owner or staff determines to be inaccurate or vulgar in nature will be removed, with or without prior notice. Appropriate sanctions may be applicable.
Please note that with each post, your IP address is recorded, in the event that you need to be banned from this forum or your ISP contacted. This will only happen in the event of a major violation of this agreement.
Also note that the software places a cookie, a text file containing bits of information (such as your user name and password), in your browser's cache. This is ONLY used to keep you logged in/out. The software does not collect or send any other form of information to your computer.
« Reply #2 on: February 21, 2007, 04:32:48 PM »
Robert,  is someone not following the rules?  Hope to see you and the rest this weekend.  DOC Holliday
« Reply #3 on: February 21, 2007, 04:45:15 PM »
I promise, Robert, I only post my own stuff.   n1
« Reply #4 on: February 21, 2007, 07:27:14 PM »
my own stuff is all that is worht posting  HA HA
Online RC Storick
« Reply #5 on: February 22, 2007, 05:23:25 PM »
If anyone spots something that has a copyright, Please let the admin staff know and we will remove it A.S.A.P. I  hvae no way of knowing what is and what insn't copyright as this is a public board. Please post only works of your own.
« Last Edit: February 23, 2007, 05:41:44 AM by Robert Storick »
