  • July 17, 2025, 09:21:45 PM
Author Topic: Copper or brass  (Read 3846 times)
Offline Larry Fernandez
Copper or brass
« on: March 21, 2012, 01:27:42 AM »
What is the correct tubing to use in a fuel tank, coppper or brass?
Larry, Buttafucco Stunt Team
Online Howard Rush
Re: Copper or brass
« Reply #1 on: March 21, 2012, 02:11:04 AM »
The Jive Combat Team uses gold.
Re: Copper or brass
« Reply #2 on: March 21, 2012, 02:14:36 AM »
  Copper.
Offline Wayne J. Buran
Re: Copper or brass
« Reply #3 on: March 21, 2012, 05:43:38 AM »
Copper by all means>
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
Offline Andrew Tinsley
Re: Copper or brass
« Reply #4 on: March 21, 2012, 05:54:58 AM »
You can always use brass if you want, but try bending it and then you will see why most people use copper! I don't know if it is true in the US, but a lot of manufacturers still use brass this side of the pond. What on earth makes them do it, I don't know! Maybe cost?
Andrew.
BMFA Number 64862
Re: Copper or brass
« Reply #5 on: March 21, 2012, 06:26:59 AM »
Use copper. The reason is brass will corrode and split. Copper is more stable for our use. Most tanks were made with Brass tubing until about 20 years ago. Then people started to have a lot of problems with the Brass tubing splitting length wise. The Brass suplied to the hobby industry was being made from flat stock not extruded. That tubing would split. If you look close you can see the seem in the Brass tubing. When bike frames were still made from Cro/Mo steel tubing Reynolds came out with seamed tubing that was light but didn't work as well as standard light weight tubing. It would fail at the heated joints. If you could find non seamed Brass tubing it might be OK. There is one more factor is Brass and solder and a tin tank has a reaction to each other when fuel hits it and it starts a long destruction of itself. Old style Brass tubing in a Brass tank would not have this problem. y1
Offline jim ivey
Re: Copper or brass
« Reply #6 on: March 21, 2012, 08:58:41 AM »
IMHO  it dorsn't matter. copper is easier to bend when you need to. other thsn thst. don't matter.  jim   bmotooemcs <---- figger that out. more than 50 over the last 60 years. jim
Re: Copper or brass
« Reply #7 on: March 21, 2012, 10:12:42 AM »
THE JIVE COMBAT TEAM IS GOLD !!!!!!!!!!!
Online Trostle
Re: Copper or brass
« Reply #8 on: March 21, 2012, 10:16:48 AM »
Use the copper tubing for all of the reasons given above.  Brass tubing will deteriorate and will eventually split or develop a hole and will cause all sorts of problems.  Any recommendation to use brass tubing should be ignored.
Re: Copper or brass
« Reply #9 on: March 21, 2012, 10:35:02 AM »
Where do you get copper tubing?  I use brass because that's what the LHS has.  But if I ever get good enough that crashing will become less of an issue than corrosion, I wouldn't mind using the right stuff.
Re: Copper or brass
« Reply #10 on: March 21, 2012, 10:38:09 AM »
Tim, I get mine from the local hardware store, they have a K and S metal rack with brass, copper and aluminum tubing,, ( even up to 36 inch lengths for those really long tanks)  LL~
Offline Brian Massey
    • California Car Clubs
Re: Copper or brass
« Reply #11 on: March 21, 2012, 11:11:04 AM »
I have several metal tanks I made 40+ years ago, using (drum roll please) brass tubing. There have been no failures to date. How long does the deterioation process normally take . . . have I just been lucky? And brass does does bend easily after annealling.
I guess I'll go checkout local hardware stores for copper, just to be safe.
Brian
AMA 55421
Madera, CA
Re: Copper or brass
« Reply #12 on: March 21, 2012, 11:30:11 AM »
I don't know how severe the brass problem is, but over the years I have heard of split tubing, etc., when using brass tube.  Never have heard a problem with copper.
BIG Bear
RNMM/AMM
Offline Douglas Ames
Re: Copper or brass
« Reply #13 on: March 21, 2012, 03:45:15 PM »
I've noticed the brass tubing on vintage Perfect tanks is alot thinner-walled than more modern replica tanks. ...better made too.
AMA 656546
Offline Chris Wilson
Re: Copper or brass
« Reply #14 on: March 21, 2012, 04:09:26 PM »
Putting it simply, methanol corrodes brass or more accurately 'destabilizes' it.
Hence why some engine manufacturers nickel or chrome plate their brass needle valve assemblies.
MAAA AUS 73427
Re: Copper or brass
« Reply #15 on: March 21, 2012, 04:38:30 PM »
Howard, after this public revelation, you may not want to turn your back on yoru airplane,, it could just end up missing its fuel tank,,,,
just sayin,,,
Re: Copper or brass
« Reply #16 on: March 22, 2012, 08:57:18 AM »
Here in KC area I am having hard time finding copper tubing in 1/8 for tanks.   Lots of brass tho. H^^
Offline jim ivey
Re: Copper or brass
« Reply #17 on: March 22, 2012, 09:07:34 AM »
hobby shop or hobby supply comes in1/16th and 3/32nd dia also
Re: Copper or brass
« Reply #18 on: March 22, 2012, 11:55:56 AM »
Go to the local car parts places and find one that has 1/8" tubing. One other possibility is the kits at auto parts stores for connecting oil pressure gauges to the engine. They contain a beautiful coil of bright shiny 1/8" copper tubing.
