  • July 18, 2025, 02:11:14 AM
Author Topic: Cooling vent  (Read 1228 times)
Cooling vent
« on: July 04, 2013, 07:39:15 PM »
What is the cooling ratio for venting a cowl?
Offline James Mills
Re: Cooling vent
« Reply #1 on: July 04, 2013, 08:33:26 PM »
I've always been told (a minimum) make the exhaust hole behind the cowl twice as big as the inlet.
James
AMA 491167
Re: Cooling vent
« Reply #2 on: July 04, 2013, 09:23:12 PM »
I have been using a 1 to 3 ratio. Heat really expands and needs a lot of area to escape.  I got this info from some top flyers.  Ask Jim. H^^
Thanks guys.
Hey Ty - Did not want to bother Jim on the 4th.  H^^
Re: Cooling vent
« Reply #3 on: July 05, 2013, 10:12:50 AM »
1 to 3 (intake to exhaust) is a good number.
Re: Cooling vent
« Reply #4 on: July 05, 2013, 09:16:46 PM »
A raised "lip" at the front of the outlet (generically known as a NASA vent) will create a lower pressure over whatever sized hole you've got room for and will accelerate the air through the cooling pathway.
Ted
Re: Cooling vent
« Reply #5 on: July 05, 2013, 10:56:46 PM »
Not because of expansion.  For air to expand that much at 70 degrees F, it would have to get to about 1600 degrees.
Offline Bill Johnson
Re: Cooling vent
« Reply #6 on: July 06, 2013, 08:27:23 AM »
Ted
Ted, are you referring to NACA? They did a lot of work on vents, ducts and endorsed Jack Northrop's pressure cowl work.
As an aside, has anyone attempted application of the pressure cowl principles to these smaller aircraft?
Best Regards,
AMA 350715
