  • July 18, 2025, 06:44:43 AM
Author Topic: Skyray 35 fuse drawing?  (Read 929 times)
Offline Steve Riebe
« on: May 27, 2012, 09:28:26 PM »
Hello, I'm a new guy here, and thanks in advance for any help you can give me. Would any of you have a full size drawing for a skyray 35 fuselage and doublers? Sure would appreciate a scanned copy sent to my e-mail. There's just not enough left of the crashed fuse to make a pattern.
Re: Skyray 35 fuse drawing?
« Reply #1 on: May 27, 2012, 10:01:00 PM »
This isn't what you are asking for, but may be sufficient to your needs.  It's pretty obviously not a Skyray.  What isn't so obvious is that all the pertinent dimensions are lifted straight off of one.  If no one else comes through with something better, between this drawing and your pile-o-flinders you should be able to reconstruct.
The doublers should extend back to about an inch behind the wing spar, more or less.  Start to taper them down about an inch in front of the spars.
Offline Steve Riebe
« Reply #2 on: May 29, 2012, 03:25:00 PM »
Tim, thanks for the great drawing, unfortunately it won't help much because it is considerably different then the Skyray 35. A very special thanks to Scott Ross for sending me a full size plan. You guys are awesome, really appreciate the help!
