Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 03, 2025, 07:56:03 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
Control Linkage Setup
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Control Linkage Setup (Read 2651 times)
Warren Leadbeatter
AUS-14782
Trade Count:
0
Captain
on:
April 29, 2007, 07:59:25 AM »
Hi All
I have recently purchased a Brodak Strega ARF and a Saito 62 and am now trying to put it all together.
The hardware package within the kit was damaged on the long flight to Australia and all the bit fells out, and some bits did not arrive here.
I am now trying to figure out what is missing and how to put the controls in. The notes call for me to use JB Weld to glue the metal control rod ends to the cardbon fibre pushrods. Only problem I have here is that there is no such thing as JB Weld here in Australia. I was just going to use epoxy.
Would this be ok or should I drill a hole through the rod and put some wire reinforcement in?
Any help would be appreciated.
Cheers
Logged
Warren Leadbeatter
Port Stephens, Australia
AUS-14782
Leester
2014 Supporters
Trade Count:
0
Admiral
Re: Control Linkage Setup
Reply #1 on:
April 29, 2007, 08:32:48 AM »
Warren: Just use whatever you use to glue rod inserts in your C/F push rods foe ball links and clevises. A Good epoxy should do it, next time you order from Brodak,Sig,RSM or SShobbies have them send you some JB Weld.
Logged
Leester
ama 830538
Peter Nevai
21 supporter
Trade Count:
0
Admiral
Reply #2 on:
April 29, 2007, 09:57:17 AM »
FYI JB Weld is a 2 part slow cure epoxy (with aluminum powder matrix added?) You probably have similar products in OZ. It is usually marketed as stuff to repair aluminum castings mainly found in Hardware, Marine, automotive supply shops.
Logged
Wynn Robins
Trade Count:
0
Admiral
Reply #3 on:
April 29, 2007, 01:39:01 PM »
Warren, I use slo cure epoxy on the control linkages...it works fine.
You can get JB Weld at Kmart and Supercheap auto..... FWIW
Logged
captcurt
Trade Count:
0
Commander
Reply #4 on:
April 29, 2007, 04:58:56 PM »
Devcon makes many similar products. Even a titanium-filled epoxy. It is available from many industrial supply houses.
Curt
PS. I would not hesitate to use a regular slow-cure epoxy material for the rod ends. Fill with high-strength filler to keep it from running out of the joint. Milled (glass or carbon) fibers are good for this.
Logged
Jim Morris
Trade Count:
0
Commander
Reply #5 on:
April 29, 2007, 07:00:59 PM »
One thing I might add is that I wrap my ends with thread and smear guick dry apoxy over the thread. Just a little safety precaution so it never splits, but I wouldnt be too afraid of leaving it as is. Hope this helps.
Logged
Warren Leadbeatter
AUS-14782
Trade Count:
0
Captain
Reply #6 on:
April 29, 2007, 07:20:36 PM »
Thanks Wynn! I went to Kmart and they did have JB Weld in stock. Thanks everyone
I believe that there should be some sort of physical backup to the connection. I would prefer that the ends scrwed into the CF rod. So what I am going to do is glue the end in place with JB weld, then drill a .5mm hole through the end then feed a piece of steel wire through it and then wrap wire around the outside then coat with epoxy. That way if the glue breaks the joint will still hold up and my ARF wont crash due to a control linkage failure.
Logged
Warren Leadbeatter
AUS-14782
minnesotamodeler
2014 Supporters
Trade Count:
0
Admiral
Me and my Chief Engineer
Reply #7 on:
April 29, 2007, 08:51:56 PM »
A "belt and suspenders" kinda guy, huh?
Logged
--Ray
AMA902472
Warren Leadbeatter
AUS-14782
Trade Count:
0
Captain
Reply #8 on:
April 29, 2007, 09:31:23 PM »
Yep. I've seen a few ARF's crash because of control linkage failure now. None of them were mine but I dont want it to happen to me either.
Cheers
Logged
Warren Leadbeatter
AUS-14782
Steve Helmick
24 supporter
Trade Count:
0
Admiral
Reply #9 on:
April 29, 2007, 10:02:43 PM »
We had a new Strega ARF show up at the field in the hands of a new member and retread, Pete Ferguson. This is the second one I've seen. Both had up elevator with what appeared to be neutral flap. Pete's had what looked like a very short elevator horn. He said he had problems with the hinges, and ended up doing them over...twice, I think. The flaps were also too spongy to suit him, and he made two new sets. I guess the bellcrank and leadouts are actually done here in the USA, and are said to be good stuff. I'd bet you could get a new hardware packet from Brodak's in a few days....
Logged
In 1944 18-20 year old's stormed beaches, and parachuted behind enemy lines to almost certain death. In 2015 18-20 year old's need safe zones so people don't hurt their feelings.
Warren Leadbeatter
AUS-14782
Trade Count:
0
Captain
Reply #10 on:
April 29, 2007, 11:01:23 PM »
Oh yes I should have mentioned "my friend in control line" is sending me a new hardware package. :-)
I've read a fair bit about the Strega and had heard about the flaps being too soft or spongy and being replaced. The flaps on mine look and feel quite good so I'll be leaving mine as is. Overall I'm very happy with the build. I can't see why there would be any problems setting up the hinges and controls to work properly at this stage. The only part that has already been done is the bellcrank and leadouts and they look great. The horns also look fairly normal to me... almost the same as the ones on all my other models.
Cheers
Logged
Warren Leadbeatter
AUS-14782
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
Jump to:
=> Open Forum
