  • July 15, 2025, 07:31:10 AM
Author Topic: CONTROL LINE HANDLE FINISH  (Read 6363 times)
Online Carl Cisneros
« on: November 22, 2015, 01:54:45 PM »
Folks;
What is a good type of finish for a CL handle?  Like the Brodaks or the SH Hobbies unfinished ones.
thanks much
I have 2 handles that I fly with that are sanded to shape for my hands comfort but no finish on them as yet. (each of the 2 handles are dedicated to a certain plane)
Any suggestions would be nice.
Carl
Carl R Cisneros, Dist IV
Control Line RB
Re: CONTROL LINE HANDLE FINISH
« Reply #1 on: November 22, 2015, 02:00:55 PM »
Folks;
thanks much
  I usually put on a very good epoxy finish. With forced-air drying/curing (in a food dehydrator) you can get a very durable finish in less than a day. Then I put this over it:
http://www.amazon.com/Gamma-AGT1-Gauze-Tape/dp/B002N1OG3G
« Reply #2 on: November 22, 2015, 02:01:43 PM »
I just use enough clear dope that it's water- and fuel proof.
You can make a thing of art using polyurethane varnish and a lot of sanding, but it turns out that for a lot of people, the weight of the handle impacts how well they fly -- 16 grams is definitely better than 100.
« Reply #3 on: November 22, 2015, 04:32:51 PM »
I sent a modeler, don't remember who, a couple of leather tennis racket grips. Guy doesn't know it, but they're worth around 30.00 each!
I hope he used them, or if not, pass them on to another modeler. "Send them back!!"  ;D  LL~
They come in long strips about 3/4" wide depending on the brand. Could do two handles per grip.
Quality leather tennis racquet grips are almost impossible to come by, I was told they are no longer being made.
Whoever you are, Post a photo!
I'd like to know you used them.  LL~ LL~
Charles
Offline GregArdill
« Reply #4 on: November 22, 2015, 05:15:33 PM »
Here's my latest, painted in Bondall Clear Varnish.
It finished up at 100g. I like the feel of the heavier handle, but hey, what do I know?
As the wood is Huon Pine, next one probably won't have any paint at all except to mark Up.
« Reply #5 on: November 22, 2015, 06:25:52 PM »
Thanks for the tips guys
all are good ones.
am leaning on the epoxy one mainly for sealing then sanding smooth.
Again, thanks to everyone.
Carl
Charles:  I found these buddy:     http://www.tennis-warehouse.com/catpage-LEATHERRGRI.html
Control Line RB
« Reply #6 on: November 22, 2015, 06:52:52 PM »
Hi Carl, I'll toss in one more, similar to the rest. I use the unbiased Tom Morris cable handles, they fit my knotty knuckled hand better than any other. They come raw, ready for dremel shaping of the palm pads and finger grips, then sanding and finishing. I wipe on clear Minwax polyurethane and after it dries, wrap it tightly with Walmart tennis racket tape, which follows the contours of the grip nicely. The poly and the tape are both pretty much bullet proof to all the stuff we slimers get on them. It's probably a little lighter than epoxy but both seem equally effective. I've never had the tape unwrap and it's great for non-slip grip.
Rusty
« Reply #7 on: November 22, 2015, 07:28:09 PM »
Rusty
thanks for the Poly tip
I forgot about that product.
decisions, decisions,,,,,,,,,,,,,,,,,,,, HB~>
Control Line RB
« Reply #8 on: November 22, 2015, 10:00:26 PM »
I myself don't like smooth finishes on the handles.  The best one I have is one I got off Dick Byron at VSC one year trying to tame down an air plane.  With all fuel and body sweat it is sticky but makes for a great grip so the handle doesn't slide in my hand..
« Reply #9 on: November 22, 2015, 10:12:49 PM »
Two coats of Z-Poxy finishing epoxy (sanded smooth after 1st coat), with fishing rod handle tape on the grip area. The tape protects the epoxy finish from being worn through on asphalt and has been trouble free for years & years.  y1 Steve
Online Perry Rose
« Reply #10 on: November 23, 2015, 04:29:36 AM »
I use  product called Vet Wrap to wrap the handle. Find it at Agway or TSC type stores. Maybe Amazon.
Offline PerttiMe
« Reply #11 on: November 23, 2015, 10:19:19 AM »
So, some like it smooth and some like it grippy; some like it hard and some like it soft?
« Reply #12 on: November 23, 2015, 12:19:00 PM »
I simply use a couple of coats of clear dope on the wood parts, to keep water out.  I do admit that a coat of epoxy would work better but would probably be heavier and I can't tolerate a heavy handle.   I do wrap the gripping portion of the handle with a layer of Tennis Tape.  In my opinion there is nothing worse than a handle that can slide around in your hand.  In fact I make sure mine slightly touches the outside edges of my index finger and little finger (fits exactly in other words).  I think that's very important for consistant "muscle memory".
« Reply #13 on: November 23, 2015, 12:30:15 PM »
I like Pat Johnston's method the best. He coats his handles with epoxy mixed with sand. Give it a fuel proof and sandpaper finish. I did my latest handle like this. Very nice.
Offline PerttiMe
« Reply #14 on: November 23, 2015, 12:50:44 PM »
... epoxy mixed with sand. Give it a fuel proof and sandpaper finish. I did my latest handle like this. Very nice.
hmmmm grippy but not squishy.
Reminds me of "skateboard tape" on the front strap of a 1911. Felt a little odd first but was perfect after just a little getting used to.
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #15 on: November 23, 2015, 07:18:22 PM »
I have made redwood handles with a polyurethane finish, Very light and the finish is fairly durable. But can be easily refinished if it's scratched up at all.
The redwood has some great wood grain patterns and come thru with the polyurethane finish, I have made racing, hard point and standard cable handles
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Offline Mark Knoepfle
« Reply #16 on: November 23, 2015, 07:37:33 PM »
Fred - those are some nice looking handles. Are the backs of the two cable handles like a hot rock for the adjustment?
Mark
« Reply #17 on: November 23, 2015, 07:51:04 PM »
I put a short landing gear strap, it has to be metal to keep it from slipping on the back side. It works better when there is two straps.
Fred
Fred Cronenwett
« Reply #18 on: November 23, 2015, 08:19:36 PM »
Clever! Thank you Fred.
Mark
« Reply #19 on: November 23, 2015, 08:32:54 PM »
Here's mine. You can see the sand in the finish.
« Reply #20 on: November 26, 2015, 09:57:11 AM »
Randy,
How does he get the sand through the airbrush.  When I tried it mine got all clogged up. ~^
Happy Big Bird Day
Ted
Offline Gerald Arana
« Reply #21 on: November 26, 2015, 10:17:48 AM »
Carl,
I brought some black sand from one of those islands in the pacific some years ago and used it on a couple of my handles. I coated the area that I wanted covered in epoxy and sprinkled the black sand over it. Then I put another coat of epoxy over it.
The problem that I had was; it would sand your hand after a couple flights. I think the sand was to course. A fined sand would've been better. Also I think I would use (fine) white sand next time.
Good luck, Jerry
« Reply #22 on: November 26, 2015, 06:21:48 PM »
Guys
Thanks ever so much for your suggestions, now I just have to make up my mind as to what I want to use on mine.  HB~> HB~>
Carl
Control Line RB
« Reply #23 on: November 27, 2015, 01:31:24 AM »
Carl,
   I used sandpaper and sand a long time ago, and that's exactly what happened to me. That was when I was flying a lot, and it just ate up the skin on my hand and I had blisters and callouses. I really like the gamma gauze tape, it has good grip, lasts a reasonable amount of time, and has no "give" to it.
Offline david beazley
« Reply #24 on: November 27, 2015, 05:19:05 AM »
I have taken a sheet of wet/dry sand paper (220 or 320 grit) and punched out "dots" with a standard paper punch.  I glue the dots to a painted smooth handle to add grippiness.  The dots are unaffected by water or  fuel.  Works for me.
AMA # 2817
