  • July 06, 2025, 01:45:12 PM
Author Topic: Stripper  (Read 1537 times)
Online Paul Taylor
Stripper
« on: June 07, 2008, 03:36:42 PM »
Anyone know of a good stripper for getting Rust-Oleum off a plane without attacking the glue joints?
Paul  H^^
« Last Edit: June 07, 2008, 05:08:42 PM by rootbeard »
Offline Jim Oliver
Re: Striper
« Reply #1 on: June 07, 2008, 03:47:46 PM »
What kind of glue??
Jim
Jim Oliver
AMA 18475
Online Paul Taylor
Re: Striper
« Reply #2 on: June 07, 2008, 04:03:06 PM »
I am sure I have a little bit of both C/A and Epoxy all over this plane. It has been repaired.
Alan Hahn
Re: Striper
« Reply #3 on: June 07, 2008, 04:51:24 PM »
Anyone know of a good striper for getting Rust-Oleum off a plane without attacking the glue joints?
Paul  H^^
Just a tiny grammatical point:
A "striper" puts on stripes (or is a fish that runs or use to run up the Sacramento River).
A "stripper" is used to take paint off (or is a ........ n1) !
Online Paul Taylor
Re: Stripper
« Reply #4 on: June 07, 2008, 05:11:42 PM »
Thanks Alan I would be lost without a spell checker.
But I still need something to take this paint off.
Offline Steven Kientz
Re: Stripper
« Reply #5 on: June 07, 2008, 05:17:40 PM »
Stripper(noun) takes off more than paint !!!!!
Steve Kientz
AMA 855912
Alan Hahn
Re: Stripper
« Reply #6 on: June 07, 2008, 05:24:00 PM »
Well a good stripper is a heat gun (a lot hotter than a Monocote gun tho') or Bix---which I have used to strip a lot of paint in my day. Not from models, but from woodwork. I think you will need aggressive  stuff like that to remove Rustoleum-like paint. You can find BIX at your hardware store. It contains lots of good hot chemicals,---acetone, methanol, and the best of all, methylene chloride. The latter is what makes a gallon of this stuff weigh so much. Anyway you would need to use it outdoors. I think it is also sold by the quart. You slop it on and let it soften the paint. Then you can scape it off. The trick in scraping it off is not damaging the soft balsa. Maybe you are stuck with sanding.
And by the way, a spell checker doesn't help if the words are real words! Like two, too, and to, led and lead, their and there......
Alan Hahn
Re: Stripper
« Reply #7 on: June 07, 2008, 05:25:51 PM »
The reason for the  n1  !
But I note the read rate has gone up since Paul corrected the title!
Offline Keith Spriggs
    • khspriggs
Re: Stripper
« Reply #8 on: June 08, 2008, 03:33:29 PM »
Here is a link to the best stripper I ever used. (no comments please). I have completely stripped several cars with it. It will remove paint, primer, even Bondo. I have never tried it but I imagine it will remove epoxy and CA. I minute' speck on your skin will burn like crazy. Probably not a good choice for wood that you intend to refinish, but great if you ever have to strip metal.
http://www.tcpglobal.com/autobodydepot/paintremove.aspx
Fifth item from the top
