It would seem Sig has redefined the ABC engine. Their "true ABC construction" has a "steel alloy" cylinder and I always thought it was chrome plated brass oh well live and learn.
Still for the price it might be worth investigating.
Andy
For instance, the connecting rods use the same aluminum alloy as found in some full size aircraft engines. Crankshafts are one piece hardened Cr steel. A specially developed "KK" bronze alloy is used for the conrod bushing which allows it to withstand high RPMs. Cylinders are made of a special heat treated Cr
steel alloy to insure a hard and true cylinder that will not distort at high temperatures. Piston rings (1.2 - 2.0 in3 engines) are made of the same steel alloy as found in some racing motorcycles. The .46 in3 is
true ABC construction. All engines contain high quality dual ball bearings.
