Right now, the FAI F2B rules allow an active speed control system for electrics. The F2B rules DO NOT allow any active speed control for IC engines other than what can be gained with combinations of tank, engine, muffler, pipe, pressure system or whatever just as long as the engine/fuel system is completely passive, or in other words, no active electronic system to control engine speed. This difference in the rules is intentional to promote the development and use of electrics in the quest to help save flying sites. If and whenever it is that these rules give such a significant advantage to electrics that IC engines clearly become obsolete, a change to lift the active control restriction on IC engine might happen, but I would not plan on that in the foreseeable future.
Dear friends, please take note of the following extract from the minutes of the CIAM Plenary Meeting of April 21 2012:
Unanimously approved by the Plenary Meeting and
effective January 1st 2013, Control Line Circular Flight F2 will be defined as follows:
12.3 Volume ABR, Section 4C, Parts One & Two
1.3.2. Category F2 – Control Line Circular Flight F2 a) Control Line Circular Flight is flight during which all control is accomplished via physical connection to the pilot through one or more inextensible wires or cables directly connected to the model aircraft. The control wires or cables must be attached to a hand held device (control handle). Automatic flight path control and/or automatic manoeuvring are not allowed.
b) Powertrain control may be accomplished by the pilot via the wires or cables or by an onboard self-contained, automatic process.
c.) For permanent shutdown of the engine(s), any device or system is permitted including the use of 2.4 GHz Spread Spectrum technology legal for use in the country of competition. The competitor will determine the suitability for use of the chosen system. Any such device or system:
1) must be operated only by the pilot, and
2) must not affect any other model.
d.) A safety strap connecting the competitor’s wrist to the control handle must be provided by the competitor and used during all flights. A pull test shall be applied separately to the safety strap. This pull test will be applied according to each class specification concerning the lines’ pull test.
e.) The regulations for classes must be set forth in class rules. Except for reasons of safety, class rules must not contradict or invalidate ABR 1.3.2
f.) Control Line Circular Flight Classes are:
F2A - SPEED MODEL AIRCRAFT
F2B - AEROBATIC MODEL AIRCRAFT
F2C - TEAM RACING MODEL AIRCRAFT
F2D - COMBAT MODEL AIRCRAFT
F2E - COMBAT MODEL AIRCRAFT WITH COMPRESSION IGNITION ENGINES
F2F - DIESEL PROFILE RACING MODEL AIRCRAFT
F2G - ELECTRIC SPEED
Related to the above: “
e.) The regulations for classes must be set forth in class rules”, the F2B Working Group will in near future initiate a decision finding process on how the F2B rule shall be adjusted accodingly.
Kind regards,
Peter Germann
F2B Working Group Coordinator
FAI F2 Subcommittee
