  • July 17, 2025, 07:44:24 PM
Author Topic: Sullivan Crap trap fuel filter.  (Read 1586 times)
Offline DanielGelinas
« on: July 09, 2012, 11:38:58 AM »
Hi Guys,
Which one do I get, small or large?
THes would be for a .29-.46 size engines.
-d H^^
Offline Gene O'Keefe
Re: Sullivan Crap trap fuel filter.
« Reply #1 on: July 09, 2012, 12:28:33 PM »
Small
Gene O'Keefe
AMA 28386
« Reply #2 on: July 09, 2012, 12:30:00 PM »
Ah ha, the one not available anywhere...
Thanks Gene!
-D
« Reply #3 on: July 09, 2012, 12:34:51 PM »
I just now looked on Tower Hobbies site and they show them in stock ...p/n LXFU76  CT-1 @ $4.29
Gene O'Keefe
AMA 28386
« Reply #4 on: July 09, 2012, 12:39:11 PM »
Hey thanks Gene... I was looking at Brodaks!
I'll check with Tower.
-Daniel H^^ H^^
« Reply #5 on: July 09, 2012, 12:47:57 PM »
My pleasure
Gene O'Keefe
AMA 28386
« Reply #6 on: July 09, 2012, 01:03:51 PM »
make sure you install the correctly with the cone shape pointing  towards the tank
Offline dirty dan
« Reply #7 on: July 09, 2012, 01:30:14 PM »
That's your best shot? When I see someone with a CrapTrap filter installed back'ards I always ask how much fuel they have run through it. If the answer is in multiples of gallons I point out the error and then make every effort toward seeing them remove the filter and then reinstall it with filter oriented properly to fuel flow.
Dan
Dan Rutherford
« Reply #8 on: July 09, 2012, 01:39:57 PM »
Dan
Geeze  Dan
If I take that approach....then what  fun would be left for you?  ;D ;D ;D ;D
« Reply #9 on: July 09, 2012, 03:22:59 PM »
Thanks Randy,
Would it make a BIG difference if not? I figure it would still filter the fuel but maybe restrict flow somewhat??
-Dan
« Reply #10 on: July 09, 2012, 03:33:10 PM »
Thanks Randy,
-Dan
Hi Dan
Seriously it needs to be put in right, The 2 filters inside are different screens,1 is very fine and needs to go after the first one, plus IF you put them in right, the debris is forced to the outside edge where it is trapped,leaving the middle clean to flow fuel, if not ,debris dirt etc.. it is forced into the middle where you do not want it to be
