  • July 22, 2025, 12:02:56 PM
Author Topic: anybody else???  (Read 932 times)
Offline Bootlegger
anybody else???
« on: July 15, 2011, 09:55:16 AM »
  Running in a couple of S T 60's that are new, choke fuel into engine, back flip prop and darn if both didn't start and run backward!!
  Has anyone had this experence???
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Balsa Butcher
  • High Desert Flier
Re: anybody else???
« Reply #1 on: July 15, 2011, 09:59:49 AM »
Yes I have, it's what happens when you store them in the same box with Cox reed valve .049s. Not really, just a little over primed, not to worry.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline W.D. Roland
Re: anybody else???
« Reply #2 on: July 15, 2011, 10:49:28 AM »
The 2 that I have in R/C use and the C/L conversion from R/C( 3 engines) will run backwards all day at low RPM throttle setting. Usually can reverse the run by grabbing spinner and releasing quickly would kick them back the right way.
I find that the C/L conversion with restrictor will run backwards from back flip sometimes will die sometime will pop and run forward and some times have to stop it manually.
These engines will almost always start first forward flip if it will bump on a pull through.
Unless your finger is slow they don't bite.
Use wood prop at least until it is sorted.
David Roland
51336
Offline Bootlegger
Re: anybody else???
« Reply #3 on: July 16, 2011, 07:42:12 AM »
 S?P   Pete C, Man you just ain't right, how did you know that they had been stored in with the cox reedies?? HB~> HB~> HB~>
Gil Causey
AMA# 6964
