Those from warmer climes would not have experienced flying in cold weather, say below 35 deg F. It has always been a bit of a surprise that after the needle is re set to match the higher air density, the 2-4 break seems to work about the same way. IMO its a temperature dependent phenomenon, so if the engine were being cooled primarily by ambient (35 deg F) air, it should have a hard time breaking into a 2 stroke at all. So the operating temperature doesn't seem to change much with a big change in ambient air temp. Hence, the cooling must come from another source, oil flow through the engine. This has always made me want to tune the system with the biggest possible outlet flow in the muffler, to get the best cooling in hot weather. My IR thermometer shows that piped engines run a good bit hotter than mufflers, and are governed by the pipe in conjunction with head temp. So let's omit pipes and their effect. But for a muffler engine, should we start to experiment with both varying the nitro content, and lowering the oil content in cold weather? Say with a mix of 2 stock fuels, one with 18% oil, 5% nitro and the second with 25% oil, 15% nitro. (Both fuels with the same mix between castor and synthetic oils.) This would add cooling oil when the added power and heat are needed, but only then. Has anybody tried this? Tom H.
