  • July 05, 2025, 02:55:36 AM
Author Topic: Combat math  (Read 2271 times)
Offline Darwin Ulledahl
Combat math
« on: May 07, 2016, 05:09:41 PM »
Had a blast test flying me Winder. This thing really moves  :o. Been 45 yrs since my last one. Need help calculating MPH. What is the speed (mph) if the radius is 63 ft, trust line to shoulder. (2.3) sec for one lap?
Darwin Ulledahl
Offline Richard Entwhistle 823412
Re: Combat math
« Reply #1 on: May 07, 2016, 05:15:35 PM »
117.234 mph
Scappoose OR
Re: Combat math
« Reply #2 on: May 07, 2016, 05:21:04 PM »
Offline Gordan Delaney
Re: Combat math
« Reply #3 on: May 07, 2016, 05:29:14 PM »
That sounds a bit to fast for a ST 35. Just my thought.
Gordy
Offline Mike Haverly
Re: Combat math
« Reply #4 on: May 07, 2016, 05:43:50 PM »
http://www.flycl.co.uk/control_line_speed_calculator.htm
Here is my work.   112.38 according to this.  That is still pretty quick for Tigre.
Re: Combat math
« Reply #5 on: May 07, 2016, 07:56:46 PM »
That's the same number I got working from first principles -- but Howard's an engineer, so I didn't want to argue with him.
From first principles:
(63 feet) * (2 * pi) / (2.3 sec) = 172.1ft/sec
(172.1 ft/sec) * (3600 sec/hour) / (5280 ft/mile) = 117.34 mi/hr
(Note that I rounded while showing my work, but carried over intermediate results -- which is absurd, because for that last .04 mph to mean anything you'd need to have measured the line length to 63 feet +/- 1/4 inch, and you'd have had to measure to less than 1/1000th of a second -- 117 mph is probably more honest).
Re: Combat math
« Reply #6 on: May 07, 2016, 08:23:20 PM »
It would be a lot easier if you used the standard 60' line length.  Then you could use the common formula:  1800/seconds per half mile.
By that formula, it works out to 111.8 MPH, disregarding the fact that you penalized yourself with over-long lines.
Re: Combat math
« Reply #7 on: May 07, 2016, 09:02:31 PM »
Thanks guy's, that's what I came up with using my high school math 117 mph. Using 60ft lines my 63ft radius length was measured from thrust line to  my shoulder as the pivot point.
Darwin
Darwin Ulledahl
Re: Combat math
« Reply #8 on: May 08, 2016, 12:57:44 PM »
If you're going that fast you better get a better prop on it.
Online Brent Williams
Re: Combat math
« Reply #9 on: May 08, 2016, 08:58:13 PM »
I'm sure you were scootin' along, but the pertinent question to ask is 2.3 seconds at what altitude?
There is a big difference between 2.3 seconds at 5 feet off the deck vs 2.3 seconds at 30+ft off of the deck.
We fly in a hemisphere, the higher you go, the smaller the circle.
Re: Combat math
« Reply #10 on: May 08, 2016, 09:03:25 PM »
Darwin
If your lines are 60' from handle center to fuselage center, the way the rules say, then you've got an awfully long arm.
