Are clunk tanks in stunt being reconfigured internally or used out of the package?
Hi Don,
I think it has been answered, but just in case............
I have used clunk tanks quite a bit, and I *plumb* them for uniflow. There is no real *need* to raise or lower the tank since the uniflow tube can be twisted to compensate. By loosening the cap and twisting it up or down, it acts like moving the whole tank. I have ran clunks with simply a feed and overflow on profiles, and made an adjustable plate for it to be fastened to. They work very well, many times, when a metal tank with enough capacity will not fit in the area given in the fuselage.
One set up is to solder the uniflow line to the pick up. This keeps the uniflow line in the same location at all times, relative to the pick up. A *Y* is fabricated with the pick up soldered to it.
Mongo
