  • July 05, 2025, 08:50:13 AM
Author Topic: Clown differences?  (Read 3565 times)
Offline David M Johnson
Clown differences?
« on: November 02, 2015, 07:35:40 PM »
A question for the experts.  Are there any differences between the PDQ Flying Clown drawn by John Jones 2005 from the PDQ kit produced by the PDQ kit from Millville NJ and the current Brodak kit?
Thank You in advance David Johnson
We're havin some fun now!!
Offline Mike Keville
Re: Clown differences?
« Reply #1 on: November 02, 2015, 07:38:24 PM »
You BET there are.  Seen here is the original $1.95 PDQ kit....quite unlike the current offering: no LE sheeting; no spars; authentic vertical fin shape.
« Reply #2 on: November 02, 2015, 08:15:10 PM »
So this first reply begs a second question what is the difference between an "A" a "B" or a "C" class engine I understand .15 vs .25 and so on but what is the "Letter" break downs mean.
« Reply #3 on: November 02, 2015, 08:20:53 PM »
In those days (we're talking 1950s here), 'A'-'B' probably meant .19 to .29, while 'C' would include .32 to .35. displacement.....the latter totally overpowered for the PDQ Flying Clown.  In the '50s we flew them on silver-case McCoy .19s, which were more than adequate.
Again, today's re-issue is NOT an accurate replica of the original Flying Clown.
Online Perry Rose
« Reply #4 on: November 03, 2015, 04:41:13 AM »
All I know is 1/2A is .049.
Offline frank mccune
« Reply #5 on: November 03, 2015, 06:48:18 AM »
    Hi:
    I will take a stab at the od lettering system as used in The Good Old Days.  The differen classes were determined by engine displacements such as below.
    1/2 A up to .050
    A .050-.20
    B .20-.29
    C .30-.49
    D .50 and larger
    I hope that my mind is still sharp! Lol
        Sincerely,
        Frank McCune
Offline bob whitney
« Reply #6 on: November 03, 2015, 08:22:11 AM »
  that looks about right then they dropped the 49's and 60's became C's  and 65's became D
rad racer
« Reply #7 on: November 03, 2015, 08:24:39 AM »
Most modern versions get the fuselage and empennage shape wrong. The lines should flow in a whimsical way but they narrow the nose, flatten the mid hump and put a blob canopy on it. The stab/elev should have a slight taper to the LE/TE but some even put the Circus Prince stab/elev on it. I have a good set of templates.
Offline Terrence Durrill
« Reply #8 on: November 03, 2015, 08:44:08 AM »
I won one of those $1.95 PDQ Flying Clown kits at a contest in Mexico, Missouri in 1956.  Not having any 19 size engines, I used a K&B .35 greenhead which slightly overpower that little stunter.  I flew a lot of combat with that plane and it was darn fast, but it turned like a Mac Truck.  I finally gave it to my brother-in-law to fly in 1966.  I think he finally threw it in the trash.......it was truly a tough little plane.   D>K
Offline Gerald Arana
« Reply #9 on: November 03, 2015, 08:52:02 AM »
And I just happen to have the "Super" PDQ Clown kit with flaps! (And NO, it's not for sale.  ;D)
« Reply #10 on: November 03, 2015, 09:12:05 AM »
Gerald,
             I also have a PDQ Super Clown with flaps which I bought as a kit at the Norfolk Naval Station in 1964.  I brought it back to Missouri and sold it to a flying buddy who built it and flew it with a Johnson .32 Sports Special.  Unfortunately, he rekitted it and threw it in the trash can.  I retrieved it and rebuilt that plane.  I flew it on and off for the next 40+ years, used it as a trainer for local kids, rekitted it twice, rebuilt it again, recovered it with parachute nylon  and it is in better shape now than originally built back in 1966.  At present, it is powered with a K&B .29 greenhead and is ready to go to the flying field.  My problem is, at age 75 and having bad knees, I am not ready to go to the flying field.  Watch out......some of these planes are so tough......they will outlive you.     D>K
Offline peabody
« Reply #11 on: November 03, 2015, 12:09:24 PM »
Many moons ago, Bill, who lived in or near Millville, allowed as how had rented some space and that it was full of, primarily, PDQ Clowns.....
He said that I could buy them for $5.00 per. I handed him $100 with the thought that the GSCB could have some fun Clown Racing.
There were at LEAST THREE distinct and different kits, all with the same crappy label (as pictured above)!
Some had cap strips on the wings, and there were a few with cheek doublers....all had what appeared the same airfoil and "numbers".
Some had what we assumed were "Circus Prince" tail feathers....
We had fun Clown Racing until Nelson's and the like appeared...
Offline bob whitney
« Reply #12 on: November 03, 2015, 06:36:04 PM »
  i was told by someone that lived in PA that the PDQ kits were built to what ever balsa they could get at the time .so leading edges and trailing edges  were dif depending what balsa they could get at the time.
rad racer
« Reply #13 on: November 03, 2015, 07:24:30 PM »
NONE of which used LE sheeting, capstrips or spars.
I rest my case.
Offline RC Storick
« Reply #14 on: November 03, 2015, 07:33:35 PM »
well here are some different clowns
« Reply #15 on: November 04, 2015, 11:06:26 AM »
I found the double kit Clown that Joe Just kitted at one time.  I also have the Brodak Clown that will not turn like I want.   Even added lead to the tail and its still sluggish.  Now I know why they race it.
Offline John Tate
« Reply #16 on: November 04, 2015, 11:15:27 AM »
An old timer told me that the Super Clown needed more elevator movement than flap movement to turn correctly.
So at the elevator control horn I moved the push rod one hole closer to the elevator and the model turned much better.
« Reply #17 on: November 04, 2015, 11:42:31 AM »
Big difference in Flying Clown and the Super Clown.   I've seen the Super Clown with and with out flaps and looked the same to me. Guess when I get caught up will have to build the Brodak Super Clown.
