  • June 30, 2025, 08:13:30 PM
Author Topic: Do you Recognize this Model or AMA Number ... Expo Bellcrank ???  (Read 1004 times)
Offline Will Davis
I purchased this well flying model in Atlanta around 1990. I flew it alot with a OS 35 s ,Span 54 inches cord at root 10"..Average size flaps , The model looked like a modified nobler /Geiske Nobler .After it's end , I salvaged the wing and tail. After checking the controls I found it had a different type of bellcrank in it , Proportional, expo ??? , Clear plastic with a pivot to change the throw at extreme angles of bellcrank
Does anyone recognize the AMA number Models  name was Stunt Bee, had 1974 AMA Nationals sticker on it . Would consider building another for Nosatalga '79 . Appears to be expert  Wing was built on rods , no kit .
Any help will be appreciated
« Last Edit: November 06, 2008, 03:34:36 AM by William Davis »
Will Davis
"Carolina Gang"
