  • July 17, 2025, 08:01:15 PM
Author Topic: Cleaner for my Ultra Sonic  (Read 1444 times)
Offline bill mazzoni
« on: November 01, 2010, 10:22:40 AM »
Need a good cleaner for my Ultra Sonic Cleaner to clean my engine parts.  I was using the crock pot with anti freeze. But want something better. Any suggestions????
Bill Mazzoni
Offline Balsa Butcher
  • High Desert Flier
Re: Cleaner for my Ultra Sonic
« Reply #1 on: November 01, 2010, 11:11:11 AM »
I have had good luck with Dawn dish detergent. I don't advise putting bearings or BB engines in ultra sonic cleaners as I have heard the bearings will vibrate and self destruct.  Dawn also makes a "Power Disolver" product that works pretty good on baked on castor without a crock-pot or ultra-sonic cleaner. I've found it at Walmart. 8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #2 on: November 01, 2010, 12:05:53 PM »
Pete-
Watchmakers have been cleaning high dollar mechanical watches in the ultra sonic machines for many years. Based on this, I doubt that ultrasonic cleaning would be harmful to bearings. For cleaning solution, I would get watch cleaning solution from Borel in Kansas city. I had a machine but gave it to a neighbor who does clocks for a living.
Don
Offline Rob Killick
« Reply #3 on: November 01, 2010, 02:43:01 PM »
Hi ,
ultrasonic cleaners may cause false brinnelling of bearings , if left for a long period of time in the us cleaner .
Just my two cents worth .
Rob K.
Rob Killick , MAAC 33300
Offline Lauri Malila
« Reply #4 on: November 01, 2010, 02:57:12 PM »
 Hi.
 There are rarely ballbearings in mechanical watches. Basically only in the oscillating weight of some selfwinding watches.
 Besides, watches are allways supposed to be fully dismantled for cleaning.
 And, watch parts are so small and light in weight that they will not be damaged if they rub against each other in the cleaning baths. If the parts have a sensitive finish, they are washed separately to prevent scratching.
 It really is not recommended to wash complete ball bearings in ultrasonic bath, unless you completely dis-assemble the bearing.
 Lauri
Offline jim ivey
« Reply #5 on: November 01, 2010, 07:20:23 PM »
trichloroethane! do ya feel lucky?,  well do ya? no kidding its what we used at LMSC in the big version ultra-sonic parts cleaning tank. It does a wonderful job. Parts come out clean and dry no residue. I;d spray it with something like WD-40 right quick though because the steel parts will rust really fast. jim
Offline Brian Hampton
« Reply #6 on: November 03, 2010, 11:38:20 PM »
I use the CLR Oil and Grease Remover (black bottle) in my u/s cleaner and have no hesitation cleaning ball races in there either because I simply can't imagine that the forces from the vibrations could possibly be enough to brinell a race. I mean, it's not like you're hitting it with a hammer :).
« Reply #7 on: November 07, 2010, 11:12:31 AM »
Thanks for the help with the ultrasonic cleaner.
Bought some Dawm Cleaner for the ultrasonic.  Also bought some Dawn- Power Cleaner to do the pre-cleaning before putting in the ultrasonic.
WORKED GREAT.  Will buy some CLR and try that out also.
Thanks Again
Bill Mazzoni
Offline Phil Coopy
« Reply #8 on: November 07, 2010, 12:55:37 PM »
Jim (Ivy)...brings back memories.....we used to use those big u/s cleaners to clean teletype machines in the '60's.....cleaned 'em up great.....then we dipped them in 10wt oil and sprayed 'em with hot water to get off the excess. I remember if you turned the main shaft over before you oiled them up it would start breaking small part all over in the machine.
Phil
