  • July 06, 2025, 05:30:15 PM
Author Topic: Clean Muffler?  (Read 4174 times)
Offline Chris Fretz
Clean Muffler?
« on: June 24, 2017, 03:49:07 AM »
What is the best way to clean up a muffler with burnt on castor oil that won't ruin the finish?
Formerly known as #Liner
AMA 1104207
Advanced
Offline Chris Fretz
Re: Clean Muffler?
« Reply #1 on: June 24, 2017, 03:50:20 AM »
Maybe polish it too...
Sent from my SM-G920V using Tapatalk
AMA 1104207
Advanced
Offline kenneth cook
Re: Clean Muffler?
« Reply #2 on: June 24, 2017, 04:14:00 AM »
            Try Mother's aluminum polish.
Offline Jim Oliver
Re: Clean Muffler?
« Reply #3 on: June 24, 2017, 04:54:05 AM »
I don't usually let mine get quite that bad before cleaning but 91% alcohol and a stiff nylon brush does a good job of removing the baked on oil.
If the oil is really hard (yours looks like it qualifies) you will need to soak in the alky for a while to soften it up.  I haven't tried heating with hot air gun but that may also soften the oil enough to make it easier to remove.
Jim Oliver
AMA 18475
Re: Clean Muffler?
« Reply #4 on: June 24, 2017, 05:57:21 AM »
  Use the same crock pot method you would to clean the engine, or find some Dawn Pwoer disolver for cleaning pots and pans. Then as was mentioned, get after it with some aluminum polish and repolish it frequently to keep it that way.
Re: Clean Muffler?
« Reply #5 on: June 24, 2017, 06:24:11 AM »
Original finish is just polished aluminum. Just sand it with 600,1000,then 1500. Polish and it will look better than new. Very easy and it does not take long.
Offline Don Jenkins
Re: Clean Muffler?
« Reply #6 on: June 24, 2017, 06:34:05 AM »
Demon Clean, brush it on, wait a few minutes, wipe it off.  Use a small stiff nylon brush to get into the crevices.
Don
Offline Chris Fretz
Re: Clean Muffler?
« Reply #7 on: June 24, 2017, 07:40:35 AM »
I was trying that last night but wouldn't touch the the stuff.
I bought it from a guy on here and that's how it looked when I got it.
I bought a crock pot at a garage sale for a $1 minus the lid for that sort of thing. I read it pits the aluminum, not sure I haven't tried it yet.  What does a blue LA look look after doing that? Dull or like the silver Las?
Don
Where did you get that at?
AMA 1104207
Advanced
Offline Don Jenkins
Re: Clean Muffler?
« Reply #8 on: June 24, 2017, 08:52:44 AM »
Brodak's has the Demon Clean.
Don
Offline Chris Fretz
Re: Clean Muffler?
« Reply #9 on: June 24, 2017, 09:48:37 AM »
I'll probably end up doing that.
AMA 1104207
Advanced
Online Gerald Arana
Re: Clean Muffler?
« Reply #10 on: June 24, 2017, 10:13:35 AM »
Do it the easy way.......... Get some "Prestone" aluminum friendly anti freeze
and stick it in the crock pot over night and it will come off with an acid brush which has been cut down to 1/4" bristles.
Then you'll have a clean surface to start your polish job.
Cheers, Jerry
Re: Clean Muffler?
« Reply #11 on: June 24, 2017, 11:40:27 AM »
Instead of buying something new, I use wet sandpaper, finishing with Blue Magic polish.
Offline Chris Fretz
Re: Clean Muffler?
« Reply #12 on: June 24, 2017, 10:21:23 PM »
1 step closer
AMA 1104207
Advanced
Offline Chris Fretz
Re: Clean Muffler?
« Reply #13 on: June 24, 2017, 10:23:39 PM »
Ok crock pot does do pretty good. I guess I'll sand and polish now.
AMA 1104207
Advanced
Re: Clean Muffler?
« Reply #14 on: June 24, 2017, 10:56:45 PM »
       I have never had a crock pot treatment pit or attack aluminum. I don't think there is ANY anti freeze sold these days that isn't comparable with aluminum since there is so much of it in the radiators, heads and engine blocks these days. Someone may have a 40 year old jug of old stuff that has been sitting in the back ot the top shelf in the garage! I use low heat on my stuff. It will take paint off. Older SuperTiger engines are painted, or have some kind of coating on them. I don't know if the blue OS engines are painted or powder coated, and I haven't had the need to crock pot one yet. One product I have been meaning to try on an old, crusty engine or muffler is paint remover. I have some of that Z-Best engine cleaner and that is what it smelled like to me and if I got some on my hand is burned the same way! The stuff that has airplanes on the can should be OK for aluminum.
Offline Chris Fretz
Re: Clean Muffler?
« Reply #15 on: June 25, 2017, 12:43:11 PM »
Sweet!
AMA 1104207
Advanced
Offline Chris Fretz
Re: Clean Muffler?
« Reply #16 on: June 25, 2017, 12:44:23 PM »
 Well it's pretty obvious I just gained about 25hp with this little baby!
AMA 1104207
Advanced
Re: Clean Muffler?
« Reply #17 on: June 25, 2017, 03:54:31 PM »
Now can I send all mine for your magic touch? LL~ LL~  That looks great, but for how long? HB~>
Offline Chris Fretz
Re: Clean Muffler?
« Reply #18 on: June 25, 2017, 04:07:47 PM »
Only if you send the engines with them... you know so I can test them. LL~ Thanks though!  Now to build the ARF to go around this muffler!
AMA 1104207
Advanced
Re: Clean Muffler?
« Reply #19 on: June 25, 2017, 05:22:59 PM »
     When it'shed up like that, the surface is much smoother and things have a less tendency to stick to it. It will last a while longer if you wipe the pipe off after each flight also and well as the rest of the model. As soon as you seen some discoloration, hit it with the rag and polish again. Semi-Chrome polish is good for this, oor any polish that is for shiny motorcycle pipes. You may not even have to take it off the engine. Now, get yourself a nice aluminum spinner all polished up to go with it!
Offline Chris Fretz
Re: Clean Muffler?
« Reply #20 on: June 25, 2017, 06:04:30 PM »
What is your go to brand of aluminum spinners?
Chris
AMA 1104207
Advanced
Re: Clean Muffler?
« Reply #21 on: June 25, 2017, 08:19:55 PM »
Chris
   I generally use the Great Planes 2" spinners, or whatever size I need for a particular model. If I need a three blade, I order a Tru-Turn through the local Hobby Shop. They can order through Tower if it's a simple job with no special blade cut outs. You can also order direct through Tru-Turn. The Great Planes shaft adapter will work with either brand. Aluminum spinners cost more, but I think they are easier to work with if you have to reshape the cut outs, and if you have to they can be balanced. A polished spinner will go with just about any paint scheme, but if you need to, they can be primed and painted to match also.
