  • July 17, 2025, 10:43:17 PM
Author Topic: Spring type Clothes Pins are assembled wrong!  (Read 2628 times)
Offline Clancy Arnold
« on: May 20, 2010, 11:15:03 AM »
During my visit to Marvin Denny's home in April, Marvin showed me that spring type clothes pins are assembled wrong from the factory, for our use.  No Fooling!!
See the attached picture.
The top row are as received.  Big ends of each wood piece is on the working end. Interference!  Also the clamping area is not at the tip.
The second row, as assembled per Marvin's directions.  Small ends of each wood piece is on the working end.  Less interference and as a bonus 50% more clamping force!!
To fix yours, just remove the metal spring, reverse the wood parts and reassemble the clothes pins.  Now isn't that better?
Marvin, thanks for sharing your knowledge and ideas,
Clancy
Clancy Arnold
U/Tronics Control
Re: Spring type Clothes Pins are assembled wrong!
« Reply #1 on: May 20, 2010, 01:11:26 PM »
I guess we keep inventing things.  I have several coat hangars with the spring type clothes pins.  As a kid Mother kept wondering where her clothes pins were going.  Then she came into my bedroom one day.  I had to buy her another package of them.  Yes I remember when clothes were hung on a clothes line in the back yard to dry.  I think they smelled so much better back then.
« Reply #2 on: May 20, 2010, 02:20:11 PM »
somones yanking your chain....
why would a clothes peg have a smooth surface to hold the item on a line ?  the Hole that is created when the peg is closed in your "wrong" assembly, is designed to clip on the clothes line - given that it is usually a rope or cord this makes a lot of sense...... S?P
but for OUR modelling use  - you might be right.....  y1
« Last Edit: May 20, 2010, 03:03:31 PM by Wynn Robins »
Offline Scott Hartford
« Reply #3 on: May 20, 2010, 02:35:30 PM »
If you could stop wetting your sheets you would not have this problem! LL~
Offline Lee Thiel
« Reply #4 on: May 20, 2010, 07:36:31 PM »
I use to do that with clothes pins back in the sixties, but had failed to remember.  I used a hacksaw blade to make a new grove for the spring clip to ride in.  Thanks for the reminder.
Lee TGD
AMA791773CD
« Reply #5 on: May 21, 2010, 05:31:58 AM »
Ho many years since you've helped hang clothes on an out door line.  I remember the nylon/plastic coated lines Dad used to put up for Mother. H^^
Offline Peter Ferguson
« Reply #6 on: May 21, 2010, 09:23:39 AM »
I've been doing that for years. You can also flip the wood pieces inside out and make long clamps out of them for clamping.
Peter Ferguson
Auburn, WA
« Reply #7 on: May 21, 2010, 01:52:28 PM »
Peter
Is the third row how you described?
This give us a third assembly technique.
Factory: Jaws parallel when closed, Depth available 1 1/4 inch.
Marvin Denny: Jaws parallel at 1/16 inch open, depth available 1 1/8 inch.
Peter Ferguson: Jaws parallel at 1/8 inch open, depth available 2 1/4 inch.
Clancy
Clancy Arnold
U/Tronics Control
« Reply #8 on: May 21, 2010, 02:49:43 PM »
Yeah thats the one.
Peter Ferguson
Auburn, WA
Online wwwarbird
« Reply #9 on: May 21, 2010, 11:38:52 PM »
 Is this under the same category as building a better mousetrap? :##
« Reply #10 on: May 22, 2010, 12:34:16 AM »
the tools used BHF (before harbor freight).
Peter Ferguson
Auburn, WA
« Reply #11 on: May 22, 2010, 09:31:01 AM »
Do you rememer using them for glo plug connectors before Dubro and Perfect? H^^
Offline Greg McCoy
  • flying tiger B24 gunnery school patch Laredo
« Reply #12 on: May 22, 2010, 03:18:10 PM »
Remember how to make match gun to shoot kitchen matches?
AMA 77370
Offline George
  • Love people, Use things.
« Reply #13 on: May 22, 2010, 09:38:01 PM »
Nope...I used alligator clips.  ;D
George
George Bain
AMA 23454
« Reply #14 on: May 23, 2010, 07:10:08 AM »
Well I still use alligator clips when the head lock is dead. H^^
