  • July 06, 2025, 11:52:50 PM
Author Topic: OS FP 15 back plates on the bay.  (Read 842 times)
Offline Curtis Shipp
  • AMA 753063 / Advanced Stunt Flyer Finally
« on: August 08, 2008, 08:15:42 AM »
For those that need cover plates for LA 15 motors go to 310059156661 the man has 5 for $6.00 each delivered. They are cheaper then I can make them for. I will still make them, but get these while you can.
Curtis Shipp
Edit: I added wrong.
« Last Edit: August 08, 2008, 09:47:00 AM by Curtis Shipp »
Life is to short to be sour.
Re: OS FP 15 back plates on the bay.
« Reply #1 on: August 08, 2008, 11:22:52 AM »
It isn't just plastic backplates.  A couple of years ago I was running a Fox 35 in super slow combat.  My pitcrew spent 5 minutes cranking and didn't even get started.  Problem was a loose backplate.  The same plane and motor had been flown several times the day before and it ran just fine.  Since the backplate had the fine Fox cork gasket, just tightening the screws again did the trick.  It ran fine for another year, before we switched to another brand of combat.
