  • July 18, 2025, 08:43:25 PM
Author Topic: Randy Powell’s Ringmaster Deluxe  (Read 2275 times)
Offline builditright
  • So happy to be alive!
« on: August 04, 2010, 02:43:06 PM »
I am primarily looking for replies from all that said they are interested buying a kit of Randy Powell’s Ringmaster Deluxe.
The plans that were drawn for Randy show a built up ½” thick fuselage with 1/8 skins and doublers making the fuselage ¾” wide, then it has a 3/8 nose Tripler on the inboard side of the fuselage.
It also shows a front view of the bulkheads and a side view of the nose piece for the cantered engine, and just so you know; I am including the two plywood bulkheads for the cantered engine with the profile version as it is currently drawn.
Okay, so here’s what I need to know from those looking to actually buy the kit.
Do you want the kit to be available as the profile (as currently drawn) or the actual cantered nose version?
Thank you and God Bless
Walter
aka/ builditright
Offline Peter Ferguson
Re: Randy Powell’s Ringmaster Deluxe
« Reply #1 on: August 04, 2010, 03:31:04 PM »
I vote cantered nose. Cantered nose is a must if you want the 40VF piped version.
Peter Ferguson
Auburn, WA
Offline George Grossardt
« Reply #2 on: August 04, 2010, 06:53:03 PM »
I'd vote for the canted nose.  What do you expect the price to be?
Offline Greg L Bahrman
« Reply #3 on: August 04, 2010, 08:56:52 PM »
I would prefer it as drawn. Perfect ship for my ST51.....but......I will buy it no matter which way it comes.......Grins
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Online Gordon Tarbell
« Reply #4 on: August 04, 2010, 09:41:03 PM »
Canted nose , is first choice.  Would also accept regular profile style nose .
Gordon Tarbell AMA 15019
« Reply #5 on: August 04, 2010, 10:24:54 PM »
Why can't you include materials for both versions in the kit?
Offline Ron Merrill
« Reply #6 on: August 05, 2010, 07:17:02 AM »
Walter, i like canted. #^ #^ #^ Ron.
« Reply #7 on: August 05, 2010, 06:03:52 PM »
Canted for the RO-Jett 40 I have that needs a new home. H^^
« Reply #8 on: August 09, 2010, 11:01:59 PM »
I suspect that either version will fly well. If you plan to use a rear exhaust engine and pipe like I did, then you have to make a choice: build the canted nose or get a trick header. I choose to build it with a canted nose. It can be tricky making sure everything is lined up, but it works pretty well.
« Last Edit: August 10, 2010, 10:33:38 AM by Randy Powell »
« Reply #9 on: August 10, 2010, 05:08:50 AM »
It's certainly a very nice plane.........either way it will be a real show-stopper. TJMHO H^^
Offline Dalton Hammett
« Reply #10 on: August 10, 2010, 06:07:42 AM »
Hi Walter
    My preference would be as drawn but I have a couple of OS 40 piped engines.  I'm just less likely to put one on a profile.
Dalton H.
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
