  • July 17, 2025, 07:36:56 PM
Author Topic: GMA Fox 35  (Read 3046 times)
Offline John Craig
Offline Jim Thomerson
Re: GMA Fox 35
« Reply #1 on: October 29, 2013, 01:52:11 PM »
I didn't see anything saying it is a GMA engine.  Suppose I missed it.
Re: GMA Fox 35
« Reply #2 on: October 29, 2013, 02:51:04 PM »
  "GMA Custom" is engraved on the head.
Offline Russell Shaffer
Re: GMA Fox 35
« Reply #3 on: October 29, 2013, 05:29:35 PM »
It either has a spare piston/liner or it has been removed? I guess the head alone could be worth $20 to many people.
Russell Shaffer
Klamath Falls, Oregon
Re: GMA Fox 35
« Reply #4 on: October 30, 2013, 01:14:22 PM »
Note that it says GMA ABC on the lug.  Chances are good it was converted by GMA and the spare parts are the stock parts that were removed.
Offline James C. Johnson
Re: GMA Fox 35
« Reply #5 on: October 30, 2013, 02:39:39 PM »
I was watching it and now it has fallen off the radar scope... the spare muffler is what got me to look... some one may got a "back door deal"....
JJ
Offline dirty dan
Re: GMA Fox 35
« Reply #6 on: October 31, 2013, 12:53:45 PM »
Sorry. Made a mistake. Dan
Dan Rutherford
Offline dirty dan
Re: GMA Fox 35
« Reply #7 on: October 31, 2013, 12:59:00 PM »
That's exactly how George identified his ABC Fox 35s. At his request I had sourced these pieces in Russia. As our agreement included GMA having exclusive access to the parts I simply shipped entire lot (less a few pieces for my own use and with George's permission), he immediately sent me payment in full. It was always easy doing business with George...
Dan
Dan Rutherford
Offline rich gorrill
Re: GMA Fox 35
« Reply #9 on: November 05, 2013, 05:19:47 AM »
what would the custom re-build include? I can tell the back cover plate is new. Did George also change the crankshaft or just balance it to cut down on the vibes?
Thanks, Rich
Offline John Craig
Re: GMA Fox 35
« Reply #10 on: November 05, 2013, 06:58:40 AM »
SWAG I suspect but do not remember for sure.  Blue printed timing to his specs for the best stunt run, crank re-balanced ,fitted & polished, ABC piston & cylinder, stuff-er back plate, sharp edges rounded for better gas flow, surface textured to better hold fuel charge. philips machine screws replaced, oil holes in each end of connecting rod.
« Last Edit: November 05, 2013, 07:22:49 AM by John Craig »
Offline BillP
Re: GMA Fox 35
« Reply #11 on: November 05, 2013, 03:45:14 PM »
I exchanged emails with GMA about buying an engine...early 1990s. He stated they were built from hand selected parts for best fit. Maybe he did major mods and didn't tell me but I didn't buy one because the impression was "hand fit only". Frank Bowman did engine work for GMA back then so he would probably know the details.
bp
Bill P.
Offline dirty dan
Re: GMA Fox 35
« Reply #12 on: November 06, 2013, 11:50:13 AM »
Thanks, Rich
Other than installing ABC piston/cylinder sets I don't know the details of GMA's other mods or even if there were any. I do know he selected a tight fit on these ABC sets and then fitted them to his own specs.
As to balance of the engine, that was one of the issues meant to be dealt with in use of an aluminum piston. In my experience it surely helped although such is difficult to quantify.
Dan
Dan Rutherford
Offline John Craig
Re: GMA Fox 35
« Reply #13 on: November 07, 2013, 06:52:52 AM »
I found some old, 1996, GMA paperwork. If you sent Geo your new Fox 35 he would customize it for $40.  For $60 you could buy just the ABC piston & liner.  His ABC custom engine was $110-120 range: his engine, ABC, his custom work, stuff-er backplate, no hemi-head, no muffler.
