  • June 16, 2025, 12:30:52 PM
Author Topic: Flying 4/22/09  (Read 1194 times)
Offline Matt Colan
Flying 4/22/09
« on: April 22, 2009, 03:58:24 PM »
After a couple of days of rain and cold weather, we got lucky and went out to the field (my backyard) for some flying.  My grandfather brought out his F-14 Tomcat designed by Vic Macaluso.  I flew my Ares and my Smoothie.  Grandpa flew first with the F-14 powered by a PA 40.  After that flight he decided that it needed a tank shim.  I flew the Smoothie next and put it through a good 480ish pattern with pattern points (so a good 455ish pattern).  After that Grandpa went back to get a handle so I cut the grass.
He got back and he flew the F-14 again with a different handle just for the heck of it.  I then brought out my Ares to see what I could do about the engine.  First flight the motor was not running steady at all.  Next flight I took muffler pressure off and the steady run came back, but the tank shim wasn't right.
While picking up and cleaning the planes off, I told Grandpa to tweak the flaps and he tweaked them a little too far.  While tweaking the flaps, the flap cracked about a foot down it.  Now while I am going away on vacation, he is going to fix the flap.
Re: Flying 4/22/09
« Reply #1 on: April 22, 2009, 04:09:37 PM »
Glad you got some handle time.
Re: Flying 4/22/09
« Reply #2 on: April 22, 2009, 06:38:52 PM »
Thanks for the story Matt.
You have a very nice looking fleet. H^^
Re: Flying 4/22/09
« Reply #3 on: April 22, 2009, 08:02:41 PM »
Glad you and Grandpa got some flights in.  As far as tweeking flaps, I have been told numerous times not to do it.  It upsets a few other things.  A trim tab should be used.  DOC Holliday
Offline Matt Colan
Re: Flying 4/22/09
« Reply #4 on: April 23, 2009, 05:16:25 AM »
The Ares, and the Smoothie is mine.  The F-14 is my grandfathers.  The Smoothie has definitely seen better days and before I take it and the Ares to Brodak, I'm going to fix up some bad spots, respray my letters (I originally used red magic marker and it looks terrible).
