  • June 18, 2025, 12:42:13 AM
Author Topic: Trim Question  (Read 1847 times)
Offline Phil Coopy
Trim Question
« on: August 05, 2006, 11:12:20 AM »
I am using a Twister to learn the sequence. I have noticed that at the top of an outside looping maneuver, (like the 2nd loop of a horizontal 8 or an outside square), that sometimes my plane wants to roll towards the inside of the circle, especially if the turn is tight or the plane is slowing. Can this be trimmed out?
Phil
Offline Richard Grogan
Re: Trim Question
« Reply #1 on: August 05, 2006, 12:57:22 PM »
Phil,
Sounds like your flaps are slightly out of balance/alignment giving you a slight aileron effect. May be your flap control horn is slightly twisted....Your outboard flap may have a slight upward warp, more noticable on outside maneuvers. Just some guesses though....Im sure some of the experts can help dial you in.
Good luck!
RG
Long Live the CL Crowd!
                  AMA 85745
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: Trim Question
« Reply #2 on: August 05, 2006, 05:23:54 PM »
Could be several things but if the airplane is straight it sounds like you may have too much tip weight causing it to hinge on hard outsides. It probably does just the reverse on hard insides, (roll away from you)  but that is less noticable.
Re: Trim Question
« Reply #3 on: August 05, 2006, 07:54:38 PM »
  Almost certainly. In general, if it's different on inside and outside turns, you have a warp or need a flap tweak. It's like putting in a little aileron effect. Tweaking the outboard flap down relative to the inboard will give you more line tension on outside maneuvers than inside. Tweaking the outboard flap up compared to the inboard will give you more line tension on insides than outsides.
    It's not entirely clear which way it needs to go from your description. Bob seems to have interpreted it in the opposite way that I did. So, just to make it clear, on outside turns, do you see the bottom of the airplane, or the top of the airplane?
Offline Phil Coopy
Re: Trim Question
« Reply #4 on: August 05, 2006, 08:57:00 PM »
When I come up to the top of an outside loop the airplane wants to go a little loose on the lines and at the same time rolls to the left (like in RC) showing me the top of the plane then as the lines tighten up it corrects itself. I'm currently carrying .95oz in the wing tip.
Phil
Offline Louis Rankin
Re: Trim Question
« Reply #5 on: August 07, 2006, 03:44:10 PM »
What is your engine size and how much does the model weigh?
Louis Rankin
Somerville Tennessee
AMA 10859
Offline Phil Coopy
Re: Trim Question
« Reply #6 on: August 07, 2006, 07:33:33 PM »
LA40 powered Twister weighing in at 44oz.
Phil
