  • July 02, 2025, 01:19:26 AM
Author Topic: Chipmunk engine?  (Read 1542 times)
Online Clint Ormosen
Chipmunk engine?
« on: October 10, 2007, 11:50:29 PM »
Some of you know that I started a JVL Chipmunk kit for VSC 20. My intention was to use a Brodak 40 in it, as the plans show. But I also have a new OS 46LA that I could use. I like the Brodak engine run and am not familiar with the OS 46. Is there really enough of a power difference to justify going to the 46? Also, the 46 is taller and will be harder to hide in the cowl.
Opinions?
Re: Chipmunk engine?
« Reply #1 on: October 11, 2007, 01:16:11 AM »
  The .46 will also require you to use .018 lines. If the plane finished out anywhere under 50 ounces, I would go with the .40. I have flown a Super Chipmunk quite a bit with .40's and .46's, and i like the smaller lines better. If I felt I had to have a .46 in it, it would be a classic ST .46. Properly trimmed, that combo can handle the extra drag of the .018 lines, I think.
   What kind of kit is it?
   Good luck and have fun,
« Reply #2 on: October 11, 2007, 04:11:17 AM »
Oh yeah, I forgot about the 018 line requirement for the .46. I don't want to do that. The Brodak will be fine.
The kit is one of Walter Umland's kits. The classic legal VanLoo Chipmunk.
steven yampolsky
« Reply #3 on: October 11, 2007, 06:46:46 AM »
I fly my JVL Chipmunk with B40. It has PLENTY of power plus like Dan wrote: .015 lines are not allowed with LA46.the model also balances properly with B40. With LA46 you will need to add tail weight.
« Reply #4 on: October 11, 2007, 08:58:06 AM »
As stated, go with the B-40.  I remember back in the 70's a young man building and flying the Sig Chipmunk as designed by Jim Van Loo kit.  It was powered with a Fox Stunt 35 that was box stock with no muffler.  it was flying so slow I kept waiting for it to fall out of the air.  He would do the whole pattern, but, would not fly competition.  Keep us posted.  DOC Holliday
« Reply #5 on: October 11, 2007, 09:59:16 AM »
The Brodak it is. Thanks for the imput guys.
« Reply #6 on: October 11, 2007, 10:51:21 AM »
Pete Peterson's awesome Van Loo Chipmunk (also an Umland kit) uses a Brodak 40. Pete's dinked around with it a bit and it runs very well. Plenty of power.
Does Brodak still sell this engine with the giant venturi? A friend had one that kept running away on him unless he overloaded it with a big prop. We finally got him to change out the enormous stock venturi for a smaller one and it solved the problem and the engine runs great and very consistent. Just wondering.
« Reply #7 on: October 11, 2007, 11:20:54 AM »
Randy, as far as I know, they still come with the tall venturi. So does the .25.
