  • July 01, 2025, 03:59:31 PM
Author Topic: Check the balance?  (Read 1047 times)
Offline Chris Fretz
Check the balance?
« on: February 10, 2018, 05:59:52 PM »
So the instructions on the Vector 40 says to hold the airplane 3 1/4in back from the leading edge.  Basically the same kind of institutions on my Score. So my question is where do you start measuring back when the leading edge tapers? Measure back from were the wing meets the fuse?
Formerly known as #Liner
AMA 1104207
Advanced
Re: Check the balance?
« Reply #1 on: February 10, 2018, 06:10:20 PM »
Unless they say different, yes.  Do they show the CG on the plans?
Keep in mind that you're just finding a starting point -- you'll want to trim the fore-aft CG along with everything else once the plane is in the air.
Offline Chris Fretz
« Reply #2 on: February 10, 2018, 06:47:15 PM »
No plans its an ARF. Just instruction booklet. Yes I am just bench trimming.
AMA 1104207
Advanced
