I have a ARF that has a LA 46. Engine has aluminum plates under the mounts and bolted on using lock nuts.
The engine will not needle on the plane. On a test stand it’s rock steady.
I’m guessing a few things:
1. Motor mounts / nose has delaminated due to age / fuel.
2. Air leak in the fuel system / tank.
The plane does seem to vibrate a lot when running. But I have been flying mostly electrics and may have lost the feel for IC. 😜
I think I have seen this in the past.
Am I headed in the right direction on trouble shooting? What am I missing?
Tanks have been a metal wedge and clunk.
Early on when I was running "thumpers" I was following Big Jim's advice at the time, as suggested by my friend Eddy R, to build a stout front end, even at the cost of some weight. At least the weight was working for me, and better than having to go add lead which is of no other use than ballast.
I used to run full length 1/2 x 1/2 maple mounts to the high point of the wing, 6/32 bolts, cross grain 1/2 between bearers, boxed in the tank compartment with the "V" diverter and the whole bit. People wondered how we got a ST 60 to swing a 13" prop with authority in a deep 4, and assumed we had hopped up motors... nope, just sturdy front ends. Motors were basically stock but gone over to make sure had a good ring, maybe a bigger venturi if we were lugging a porker, etc... but pretty much stock.
Randy Smith cured me of all that when I went to his PA's... smooth as silk. Still needed a sturdy front end, just didn't need to be bomb proof like for the ST60.
In my opinion, ARF front ends should all be beefed up before their first flight (before fuel ever touches the wood so you get good bonds). Every ARF/ARC I've owned needed something, and even with that, most still never came close to matching 1/5th the longevity of a home built.
EricV
