  • June 26, 2025, 12:20:54 AM
Author Topic: Interesting engine problem  (Read 1944 times)
Offline Gary Dowler
« on: March 02, 2019, 04:43:20 PM »
I was reading a post on another site posted by a flier. His OS 40 has, by his statements without any crash damage or ever being apart, taken to starting and running only backwards. He says it will not run normally.
What can cause this?
Gary
Offline Bill Adair
  • AMA 182626
Re: Interesting engine problem
« Reply #1 on: March 02, 2019, 04:56:13 PM »
Carbon buildup?
« Reply #2 on: March 02, 2019, 05:02:33 PM »
Carbon buildup?
  Elvin magic?  OR:
Online qaz049
« Reply #3 on: March 02, 2019, 06:26:27 PM »
Gary
Liner has rotated?
« Reply #4 on: March 02, 2019, 07:35:57 PM »
Since at least the FP series, OS engines have had a pin to clock the cylinder location, so that doesn't seem likely, especially without being taken apart. Engines usually start backwards from being over-primed, so I'd wonder if the throttle idle adjustment (air bleed) might have drifted enough to make it rich? It's either that, or the polarity has been reversed...  LL~ Steve
Offline Gary Dowler
« Reply #5 on: March 02, 2019, 07:41:08 PM »
Don't ya hate it when people get their polarity reversed??
« Reply #6 on: March 02, 2019, 08:54:00 PM »
Gary
   Well, there is running ( popping, jerking, blubbering and not really spinning up and making power) and then there is RUNNING! Not enough information here. The direction it will run is pretty much dictated by crankshaft timing, correct?  If the liner was backwards, it might not even attempt to pop.Has he tried using a starter? Pinch off the fuel line and continue to attempt to start and see if it burns off the prime and runs correctly. Something is not right and we're not hearing the whole story I think.
Offline Steve Lotz
« Reply #7 on: March 03, 2019, 03:29:11 AM »
Maybe he put a reverse rotation prop on it.
Offline Perry Rose
« Reply #8 on: March 03, 2019, 05:11:42 AM »
I had the needle set way too rich on on an Evo. .60 and it started backwards. Leaned it several turns and it ran properly.
« Reply #9 on: March 03, 2019, 11:51:48 AM »
   You know, I have seen R/C fliers do that, and I did not consider it. Most look at the 'stick" that they are bolting onto their engine and as long as it goes on the shaft, that's as far as any inspection goes. Working in a local hobby shop for 35 years lets you see all sorts of stuff! An unknowing guy starts the engine, feels the prop wash going the wrong way and he thinks it's running backwards! This could be the situation, but still fits the lack of more information need.
Offline Gary Dowler
« Reply #10 on: March 03, 2019, 12:03:56 PM »
Just FYI, I have asked for more info from this guy, thus far no response.
Gary
« Reply #11 on: March 03, 2019, 12:08:51 PM »
   That can happen - it runs only backwards because running backwards pumps out the excess fuel on each stroke. Thats the most plausible explanation, given that the rest of the engine did  not change. Some engines run better backward than others. The original version of the PA51 were notorious for starting backwards and then running very strongly that way, far more than the 40 or the 61/65. IT was because the crank timing was much longer and closer to centered on TDC. That's also why it ran more smoothly across the break, and the "Aussie Crank Mod" made the 61 do something similar.
« Reply #12 on: March 03, 2019, 12:43:12 PM »
    I don't think you will find any OS .40 with crank timing that wide. That's one of the things we don't know, which OS.40?? Supposed to be unmolested, not crashed and un-altered. I'm still curious as to what he means by "only runs backwards.". Does that mean it will throttle?  Even if a c/l version, will it needle? If so, I'll bet money on it having a pusher prop and he doesn't notice it.
     Dan McEntee?
Dwayne
« Reply #13 on: March 03, 2019, 01:18:49 PM »
     Dan McEntee?
My AX 46 will run backwards if the needle is to rich and I try and start it by hand, goose the throttle and it will quit, but will idle the tank out.
« Reply #14 on: March 03, 2019, 03:27:35 PM »
   And more to the point, it didn't change since it was working correctly.
Offline GERALD WIMMER
    • Auckland Free Flight Club
« Reply #15 on: March 03, 2019, 04:20:54 PM »
Hello
As Brett points out unless something changed on the engine, some operating procedure must have changed even something small like being too rich by changing tank height.
The other interesting possibility the springs to mind  is he has an 'unusual' OS 40 like a 40H Rat Race or Pylon that has more radical timing .
My old Enya 60II (model 7032 the one with weird crank timing) would drive me wild with its desire to run backwards when flipped so I just resorted to the electric starting it , till I changed to the latter Enya 60III model 7033 with more normal crankshaft timing.
Regards Gerald
