General control line discussion => Open Forum => Topic started by: Mike Griffin on February 19, 2023, 01:04:05 PM
Here is a question for anyone who may know the answer.
If I have a wing that has a 52" span counting the wing tips and a root chord of 12 1/2 inches at the center and 10" at the tip (not counting the wing tips), and I want to make it a barn door type wing with a constant chord of 12 1/2" all the way across, is there any adjustment you would need to make in span one way or the other? The current leading edge is straight with a swept forward trailing edge (ref the chords) . I know I had this discussion with Allen Brickhaus years ago and he said yes but I cannot remember what he told me.
Thank you
To do what, keep the same area? Your starting wing area is 11 1/4 x 52 = 585 square inches. To get the same area with a constant 12 1/2" chord, your wingspan should be 585/12 1/2 = 46.8", say, 46 3/4".
However, that takes your already low aspect ratio (ratio of span to average chord) from an already-low 4.6:1 down to an extremely low 3.75:1. That will drastically increase the induced drag when maneuvering, meaning it will slow dramatically in the corners and make extreme demands on the power/propulsion. If this is for sport/stunt, be prepared to get the honkin'est very low pitched piped IC system or very large feedback electric (since the drag will also require a massive battery to make it through a flight).
A more typical aspect ratio for stunt models about this size is 5.2-5.5:1. For 585 square inches, that's a span ~56" and an average chord of 10 3/8". That will demand far less of the engine/propulsion than even 4.6:1, without being so high as to cause other issues
If you meant to adjust it for something else or for some other goal, I think we need to know what the goal might be.
Brett,
Thank you. You told me what I needed to know. I was trying to figure out if I wanted to take the wing I described and make a constant chord wing, what chord width should I use for the ribs. If I understand correctly, if I did this, the constant chord should be 10 3/8? This is not a flapped wing. That was the goal.
Brett,
If that was the point, you are no longer modifying it ,you are designing a new one.
If you just want a straight-wing equivalent of your original tapered wing, I think you want 11 1/4" chord - the average chord of the original. That will give you a constant-chord wing with 585 square inches, and an aspect ratio of 4.6:1, same as you started with
That was what I was after. I guess I did not explain it well. Thank you again.
