  • July 14, 2025, 08:58:03 PM
Author Topic: Challenge accepted- Cricut 1/8 inch letters  (Read 1176 times)
« on: February 09, 2025, 12:54:48 PM »
Sparky said he doubted my cricut would cut 1/8 in letters.
It will cut them just fine. Even smaller.
The problem is weeding them to use as a stencil. Need a magnifying glass and tweezers.
« Last Edit: February 09, 2025, 02:53:59 PM by Paul Taylor »
Re: Challenge accepted- Cricut 1/8 inch letters
« Reply #1 on: February 09, 2025, 01:31:17 PM »
  Interesting. WHat would be easier is to find a way to make our own LetraSet dry transfer lettering!! The model rail roaders do have some sheet available all the way down to N-Scale but then you need to "build" what you want it to read. I did that by laying them out on clear decal paper, spray them to seal them, then apply like normal. But I guess you can just print what you need on a printer on decal paper and then do the same . I just refuse to try and keep a printer in house just to make the ink people rich!!
« Reply #2 on: February 09, 2025, 03:44:57 PM »
Not Letrasets but I wonder if HTV could be could be used and buried in clear using light coats?
I made mine a little larger and stuck them on. No fuel.
Offline frank williams
« Reply #3 on: February 09, 2025, 04:55:06 PM »
Why not decal paper in a printer?
« Reply #4 on: February 09, 2025, 05:04:11 PM »
I was asked about cutting a 1/8 inch paint mask.
But like Dan said. Ink is expensive.
« Reply #5 on: February 10, 2025, 01:14:45 PM »
My InkJet printer got used so infrequently that the ink cartridge was always Tango Utah. Got a laser printer now, which I also seldom use...mostly recipes that the spousal unit won't even try to use. If it doesn't come out of the freezer or a box, it's too confusing for her, near as I can tell.   R%%%%  Steve
