  • July 17, 2025, 07:47:27 PM
Author Topic: CF Pushrod Wall Thickness  (Read 1547 times)
« on: August 23, 2015, 09:50:07 PM »
I found some CF arrows at Walmart and brought one home. it has an OD of 5/16" and a wall thickness of .025". Would this be strong enough for say a Vector 40 size plane? They do seem to have a little more flex than I thought they would but, still better than wire. Just worried about failure.
Online Curare
Re: CF Pushrod Wall Thickness
« Reply #1 on: August 23, 2015, 09:58:45 PM »
Are you sure they're carbon and not black fibreglass?
I've used Easton carbon arrow shafts before, but they were 8.1 grains per inch. These were the toughest I could buy, and even then I think they're a little bit flexy.
Greg Kowalski
AUS 36694
« Reply #2 on: August 23, 2015, 10:20:28 PM »
The arrow shafts that I have that are that size would certainly work -- but I'm pretty sure mine are, indeed, carbon.
Do they say they're made out of CF, or are they just black and made out of something fibrous?
Offline David_Stack
« Reply #3 on: August 24, 2015, 06:36:34 AM »
Arrow shaft 'spine'...
Good Morning,
  Arrow shafts are sized/selected based on a numeric value indicative of their 'spine'.  The challenge is that while there is an industry standard (as developed by Easton archery) not all of the arrow shaft manufacturers us it to boldly label their arrow shafts.  In archery, spine = the amount of shaft deflection when a set weight (1.94 lb) is suspended from the mid-point of the shaft, with the shaft resting on two supports spaced 28" apart.  A 500 spine arrow would have a deflection of 0.500" when tested using the criteria mentioned, a 350 spine arrow would deflect 0.350", and so on.
  For our use, you are obviously going to want to select the lowest spine (shaft most resistant to bending) which you can find...
r/
Jim Roselle
« Reply #4 on: August 24, 2015, 07:57:33 AM »
Or you can do this, best 6.95 you'll ever spend.
http://stunthanger.com/hobby/product_info.php?products_id=312
Offline Bill Johnson
« Reply #5 on: August 24, 2015, 09:26:25 AM »
I guess you specify the length when you order? If so, that is a deal. I can't buy the parts for that much!
Best Regards,
AMA 350715
Jim Roselle
« Reply #6 on: August 24, 2015, 09:53:53 AM »
Yep, I ordered one last Monday and it arrived Friday.
« Reply #7 on: August 24, 2015, 10:58:05 PM »
Well saw it in half and see how thick it is.
Offline Al Ferraro
« Reply #8 on: August 26, 2015, 09:19:54 AM »
« Reply #9 on: August 27, 2015, 06:53:09 AM »
This might be helpful.
http://www.darrolcady.com/Carbon_Fiber/carbon_fiber.htm
Thanks for the link, Al. I like the 3/16" rod that takes all-thread. Much cheaper then the rods and titanium fittings from the LHS.
Best Regards,
AMA 350715
