General control line discussion => Open Forum => Topic started by: Mike Griffin on December 16, 2016, 12:39:52 PM
I want to build a Cessna 172 model (either a CL or RC version) to hang in our CAP hangar. I am going to paint it in the CAP colors and scheme if I can find one. The only kit I have been able to find has been a Guillows kit and I really don't want to use it if I can find another manufacturer, Is anyone aware of a kit out there anywhere?
Thank you
Berkley made a 1/4A sized one (mine flew...not well), and I believe they made a larger version, which I think would work well for your purpose. But then, they were terrible kits. Plans weren't all that bad, and may be available from AMA or other sources.
I would not be shocked to find out that there is an R/C kit or ARF out there that might work for you. Maybe a tour of Tower or some of the online R/C hobby vendors would pay off. Good hunting! D>K Steve
Thank you Steve. This is of course just a static display but I will check out and see If I might locate a Berkley kit of it...thanks again.
Other than very small plastic kits, the Guillow's is the best choice. Use the kit wood since it is going to hang and not fly. I have built one painted to represent the one I soloed in. H^^
I appreciate it Ty. I will do some looking around and see what I can find. I can always go to the Guillows...
Mike,
If it's static, there's plenty of ARF 172's for R/C. Why won't that work?
Charles
Manzano Laser works has a couple Cessna 170/172's. Pat Trittle designed a couple. I have built a couple of his designs and they are really nice builds.
http://www.manzanolaser.com/index.php?main_page=index&cPath=67&zenid=82ac404287ac8cd1d9b5402d1abed18b
Hi Mike,
Depending on the size of model you want, you may want to take a look at Wendell Hostetler's site. He has a large C 172 model available, which might be good for display. Although he only sells plans, there are sources for his kits on his site.
http://www.hostetlersplans.com/
Larry Fruits
I punched in 172 into the search function of the plans gallery at Hip Pocket Aeronautics and it came up with three or four plans. May be an option for you. H^^
Although not a 172 Sterling (back in the day) did a couple Cessna 180 tail draggers in two sizes. The small one at 17" span and the larger R/C or C/L version, kit FS-2 with a 45" span. Flying buddy Ken House had the 45" one back in the mid 1970's. (Hmm,..I don't every remember seeing it completed or fly.) It would be both a nice size model to hang over head and would be a building project. The point is mute as they are out of production. Google relates one sold on e-bay in 2015 for $79.00 Anybody got one of them in the stash? outer zone show the plans as a down load. But they do not include a pattern plan for the parts, at least I don't think they do.
http://www.outerzone.co.uk/plan_details.asp?ID=4984
(http://www.outerzone.co.uk/images/_thumbs/models/4984.jpg)
