  • July 16, 2025, 07:46:34 PM
Author Topic: Centering hinges...  (Read 1754 times)
Offline Bootlegger
Centering hinges...
« on: August 22, 2007, 09:11:21 AM »
  Hello Guy's,
  Several years ago Dubro made a Hinge Slotting tool, it had a centering device as well as a tool to remove the wood, today I use a Great Plains Slot Machine with the centering tools. BUT, some of my slots aren't centered !!!
   What are ya'll doing to prevent this ???   I need some suggestions... :! :! #^
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Jim Oliver
Re: Centering hinges...
« Reply #1 on: August 22, 2007, 09:22:30 AM »
Dacron hinges from Tom Morris! LL~ LL~
Actually, Central Hobbies has Tettra hinge centering device that works on tapered surfaces, which the Dubro does not do.   www.centralhobbies.com/tools/alignment.html#taper
Jim
Edited for fat fingering.  Also, I bought the G.P. hinge slotter--used it once and put it away.  I can do much better with a No. 11 and a metal fingernail file.
Jim Oliver
AMA 18475
Offline Jim Oliver
« Reply #2 on: August 22, 2007, 09:31:16 AM »
Not sure why the link doesn't work??
Try this one:  www.centralhobbies.com/tools/alignment.html#taper
Jim
Jim Oliver
AMA 18475
