Steve means to look at how vertical it is when you look from the nose BTW -- he's thinking that since you moved the CG up without moving the LO guides to compensate, it may fly noticeably different.
Well, actually, no. I was suggesting that moving the leadouts up in the wingtip (or heavier wheels) might fix the vertical CG, if that has become a problem. But the main point was that the LO's position fore/aft can make a big difference in the "groove" (or lack of).
I'm really thinking that he's now got upthrust in it. That would very likely make it porpoise. I'm also wondering if the engine is mounted on the top side of the mounting lugs, because some (especially the .40LA and .46LA) have a huge draft angle on the topside of them. I'd NOT want to put that surface against any mounting beams, most especially on any one of the LA's. Then again, if it's mounted on an R/C mount, and that was also turned over, then maybe it has some angle error built into it, which could be good when inverted, but bad when upright? These are some of my questions, which might be answered by a picture or two of the engine installation, and perhaps provide a clue as to the cause & solution.
