  • July 18, 2025, 09:39:13 AM
Author Topic: Cellulose glue?  (Read 15207 times)
Offline badbill
Re: Cellulose glue?
« Reply #50 on: April 12, 2023, 08:52:47 AM »
Testors cement works very well, I like it.  https://brodak.com/building-supplies/adhesives/cements.html
Bill Davenport
AMA 28141
Re: Cellulose glue?
« Reply #51 on: April 12, 2023, 10:21:24 AM »
Just used Duco on a silkspan tear, worked like Sigment! No problem at all!  Thanks again for all good info!
  I strongly suspect that it is literally the same thing, from the same chemical plant. Same with 'regular" Testors. "Fast" Testors seems to have something different as a solvent, probably more acetone and less MEK, so the solvent evaporates faster.
Offline Dan Berry
Re: Cellulose glue?
« Reply #52 on: April 12, 2023, 11:16:53 AM »
I know some serious FAC scale guys who use Duco and won't use Sigment and believe that they act differently.
