I've never quite trusted these gizmos.
Sure, Tom Morris and some other suppliers make heavy-duty hardware that works.
But in general. they're an engineering nightmare.
Torque is transmittted through a 3/32" or 1/8" rod. The force is attached to the surface of the rod, thus the lever is only 3/64" or 4/64".
Depending on the size of the flippers, the load has a moment of 1" to 1.5".
Thus, the rod is operating at a mechanical disadvantage between 24-to-1 and 32-to-1. So if there is one pound of force on the flippers, the rod/horn joint will feel 32 pounds.
This is why I favor a plain U-rod and a nylon horn on the outside flipper. If you want a front row score, buy a Morris horn for $8. If you just want to fly a Top Flite Score, do it my way for next to nothing, and have easy adjustment to boot.
If you're just trying live with an existing ARF, you could abandon the stock wire horn in place and bring the pushrod to a stout outdoor nyon horn.
