  • July 18, 2025, 09:04:32 PM
Author Topic: Carton To Ship Kit  (Read 937 times)
Offline Dick Pacini
Carton To Ship Kit
« on: March 26, 2025, 08:03:48 PM »
I have a kit that I want to ship.  It is 45 X 6.25 X 4.  Any suggestions where I can obtain a suitable container?
AMA 62221
Re: Carton To Ship Kit
« Reply #1 on: March 26, 2025, 08:55:50 PM »
   You will have trouble finding a suitable box for double boxing. And that just tends to add on to the cost of shipping these days because the size and girth is larger. I have been going to the local U-Haul store and buying their specialty boxes that are almost 50" long and about a foot square, and then use the material t make a corrugated wrap for the kit box. These boxes are for floor lamps or something similar, may even be for golf clubs, but they only cost about 7 or 8 bucks and if you are careful you can get two wraps out of one box.
    You just need a large work table to start with. Also a long straight edge, pencil and a dull pizza cutter. I cut the box lengthwise down the corner where the seam is, then lay it down and the kit on it and bring it up to about half way across the kit box. I trace a line with the pencil, then enhance it with the straight edge. That will be your first fold and where the DULL pizza cutter comes in. Run the pizza wheel down the liune along the straight edge to guide it. That will make a score that will allow you to fold it there. Make that first fold and hold the kit box against the flap and make another line. Again, enhance it and run the cutter down it to make a score for the next fold. Continue this around the box until you get to where you overlap the first edge, and do that by at least 2" and make a line there. That is your basic box. You can then cut and fold the end panels as you desire, or trim the wrap even all the way around, and using some scrap, cut end panels that measure what the new dimensions are and hold them on with tape. Once you make the first one, it gets much easier and kind of like building a model!! You will add some weight to the shipping cost but no added weight from packing material like you would need for an over sized box. and probably save 10 bucks or more due to the reduced girth measurement. I hope this all makes sense , I'm kind of tired!! I have had great success send kits out this way and also receiving them wrapped like this. I think others will agree.
« Reply #2 on: March 26, 2025, 09:03:29 PM »
 Start with a big sheet of cardboard and make your own.
Online Paul Wescott
« Reply #3 on: March 26, 2025, 10:04:25 PM »
Check behind your local flower shops.  Or ask inside.  On delivery day, and sometimes the next day, I find dozens and dozens.  Many are not close to 45” but usually some are.
Offline Peter in Fairfax, VA
« Reply #4 on: March 26, 2025, 10:57:51 PM »
Yes, cut and fold your own.
As Dan points out, U-Haul has boxes that can be cut down.  Furniture, appliance, musical instrument and sporting goods boxes (bicycles, fishing rods, golf clubs/bags, etc.) can also be used as a source.  Myself, I'd avoid boxes that have contained food or plants.
I guess a pizza cutter would work at the fold lines, but it's pretty easy to cut one face with a typical utility knife.  Tools needed:  ruler/straightedge, knife, marking pen.
Peter
Offline jerry v
« Reply #5 on: March 27, 2025, 08:12:52 AM »
Bicycle boxes from their store dumpsters. Usually 7 inches wide, double wall cardboard.
Jerry
Variety is the spice of life.
« Reply #6 on: March 27, 2025, 12:45:34 PM »
I recently shipped a kit via USPS ground. What I did was cut an oversized box into two "L" shapes the proper size and taped them to the kit box. Worked fine, but basically only going from Seattle to Sacramento.
IMO, the longer they have it and the more times it's diverted, the less likely an item will survive, but I haven't had any horrible experiences with USPS. FedEx is THE WORST!  y1 Steve
Online Gerald Arana
« Reply #7 on: March 27, 2025, 07:22:19 PM »
Awww, you beat me to it Wayne. That's exactly what I've been doing when I need to ship a big kit.
Good luck, Jerry
