  • June 20, 2025, 05:34:26 PM
Author Topic: Fox 36 mk 6 Winder Maiden flight  (Read 2557 times)
Offline kevin king
Re: Fox 36 mk 6 Winder Maiden flight
« Reply #1 on: June 23, 2024, 11:47:36 AM »
Turning in the mid 16's. What NVA do you have in there?
Offline kevin king
« Reply #2 on: June 23, 2024, 06:30:46 PM »
I have one of the fine thread japanese NVAs in it. No drilling was required in the stock case
Offline Robert Whitley
« Reply #3 on: June 23, 2024, 07:43:26 PM »
Way to go Buddy!!!
Looks and sounds great!
Were you dizzy after?
Offline kevin king
« Reply #4 on: June 24, 2024, 06:43:23 AM »
Thanks Bob, I was dizzy after the first flight. The 2nd and 3rd flight i was fine. Spacing at the handle was to wide, The prop needs more pitch, and the engine needs more nitro. Thanks for your help, Paul Gibeault's help and Mike Thiesen's help.
Offline kevin king
« Reply #5 on: June 24, 2024, 10:53:28 AM »
Against my better judgement i decided not to install a tip weight box. Now I am flying around with double the tip weight i need and have to cut into wing to drill it all out. Unreal. Ya, i dont need adjustable lead outs or tip weight box some say. But this is not a box stock Winder with a fox 35 or 36x with a crankcase pipe sticking out the back. How you going to fine tune it? There is no reference. I didnt build 3 identical models and adjust the trim after the last. Maybe i should fly it with one of those 5" spaced sullivan handles too.
