  • June 30, 2025, 01:57:57 AM
Author Topic: Cardinal profile tip weight?  (Read 1318 times)
« on: June 10, 2018, 02:26:30 PM »
What is the weight of your Cardinal profile wing-tip weight?
Online Tim Wescott
Re: Cardinal profile tip weight?
« Reply #1 on: June 10, 2018, 04:01:43 PM »
If I had a Cardinal, it would be adjustable, and adjusted to whatever that particular plane needed with the particular lines I was flying it with.
Start with about 1 ounce -- that should be way too much, which is a good start.  Then adjust as needed until Stunt Nirvana is reached.
« Reply #2 on: June 10, 2018, 04:34:55 PM »
   That will not be way too much. The airplane has equal-span wings (or at least, that's what it's supposed to have, unless someone changed it). 2 to start, and that's low if if wasn't for the engine and tank out there, it might need more.
« Reply #3 on: June 10, 2018, 05:13:18 PM »
Jared Hayes has one he has struggled with.  I don't know what the airplane called for but he didn't make it adjustable and it was WAY TOO MUCH.  I suggested he start trimming away the inboard flap.  It now flies pretty well...with about half the inboard flap gone.  Looks strange but flies pretty well now.  I'm a little suspect of the airfoil at the tips though I haven't really spent much time to look into it.
Offline Mike Ferguson
« Reply #4 on: June 10, 2018, 05:25:45 PM »
Trim 5/8" to 3/4" off the back of both flaps, set control ratio to 2:3. It will fly really, really nice once that's done.
« Reply #5 on: June 10, 2018, 05:49:38 PM »
   That can happen if you build in tip weight. In that case I would dig it out, rather than trim the flaps that much differently.
« Reply #6 on: June 10, 2018, 06:37:57 PM »
I second that motion.
« Reply #7 on: June 10, 2018, 06:46:08 PM »
  Thank Ted Fancher for that one, that was invented out in the parking lot at Mission College in Santa Clara, CA, and done on-site to Paul Ferrell's Profile Cardinal. He won the Senior National Championship about two weeks later.
Offline Jared Hays
« Reply #8 on: June 16, 2018, 12:26:54 PM »
Mine is adjustable however at one time I did have way to much in it.  I went and grabbed mine and pulled the weight box to see what I have in it currently,  its 1 oz.  I had a big hinging issue with the plane before.  Where when you gave down control the outside wing would roll upward and vise versa on up control.  The more tip weight I added the worse it got.  So I started pulling tip weight out and it got better.  But still wasn't good by any means.  After talking to Dave once at a contest.  I decided to start to trim down the inboard flap.  I have ended up taking off a full inch width of the inboard flap,  and now it flies pretty well.  It just gets a lot of "looks" at the flying fields haha... But hey I won 1st in North Carolina with it 2 years ago in a class of nearly 20 competitors in its current configuration, so for an ARF its good enough for me.
