  • July 19, 2025, 01:56:06 PM
Author Topic: Carbon Spatted Wheels  (Read 1266 times)
Offline Kerry Ewart
« on: March 16, 2011, 05:24:43 AM »
I saw these a while back and thought they may be of intrest to some people on here
They are a product and manufactured by "Bruce Dechastel" from F3d Fame and have been used for years now on many pylon racers around the world.
They are 105mm from the plate to top of the wheel,2 1/4" wheel and 15mm wide spat,the top plate is 48mm x 35mm you can change that slightly.Weight 45 grams approx Each side 90 gms per pair.
Simply drill top plate and mount using 4mm bolts to a ply plate in the model,you can also trim the spat for more clearence on the wheel for grass use.
Price :- $85.00 AUD /Pair + frieght and if in australia + 10% gst.
For ordering and more information contact Bruce on email:- bdechastel@bigpond.com or through his website http://www.bigbruceracing.com
I am not selling these for bruce just thought it may be of use to the stunt people,and i will be using them myself soon
"If you cannot beat them!JOIN THEM.
Re: Carbon Spatted Wheels
« Reply #1 on: March 16, 2011, 09:52:19 AM »
Several year ago I did some carbon fiber wing mounted gear. One of the problems was that they were very rigid. Very rigid. So there was pretty much zero flex when landing. This usually caused a bounce unless it was an absolutely perfect landing. Ultimately, I had a hard landing with the plane and instead of the gear flexing, it drove the gear through the wing. I may try it again and redesign the layout to allow some flex, but I was disheartened by this outcome.
Now for something like racing, this would probably be fine as the wing structure would likely be designed to hold up to hard, fast landings.
« Reply #2 on: March 16, 2011, 06:03:48 PM »
I use Carbon landing gear from Kaz Minato which are lined with Kevlar to allow them to flex.
Spats, Legs + wheels + primer = 65 Grams.
