General control line discussion => Open Forum => Topic started by: nobler8824 on July 31, 2024, 12:54:09 PM
Title: Carbon fiber push rod
Post by: nobler8824 on July 31, 2024, 12:54:09 PM
I'm looking for the push rod kit that comes with the push rod, wooden dowels, steel rods and the plastic ends caps. Is this something that is still available?
Title: Re: Carbon fiber push rod
Post by: Paul Walker on July 31, 2024, 01:59:54 PM
Check out Central Hobbies on the web in Billings Montana. Great pushrod hardware.
Post by: Matt Colan on July 31, 2024, 03:20:19 PM
Don’t use steel. Get the titanium hardware from central hobbies. I learned my lesson with steel
Post by: Motorman on July 31, 2024, 09:56:58 PM
Not sure anyone is using the wooden dowl steel wire method any more.
Post by: RC Storick on August 01, 2024, 02:23:53 PM
I use a 1/4 aluminum tube filled with balsa then drip thin CA inside. 1/4 dowl JB welded in the end with 3/32 wire.
Post by: Colin McRae on August 01, 2024, 06:30:27 PM
https://www.youtube.com/watch?v=csdSuuxyAUA
I have been making up my CF pushrods as shown in this video. Has worked well with no issues so far.
I use a 3mm ID / 5 mm OD CF rod that I got from a local hobby shop. The 3mm ID is perfect for a threaded 4-40 stud insert.
I take a 4-40 one-inch-long bolt and cut off the head with my Dremel. This produces a 1" 4-40 threaded stud.
I use a 2-56/4-40 Dubro ball link.
I JB weld the stud into the CF rod.
Then basically follow the video means and methods to finish off.
I also drill a micro hole in the rod for air pressure relief when making up the second end of the rod. This prevents the second stud from pushing back out due to built-up air pressure within the rod so you can set the final length you desire.
Post by: Martin Quartim on August 03, 2024, 02:56:24 PM
the only problem in this process is that  if you let it cure laying flat on the table the JB will run flat to the bottom inside the tube.
I do one end at the time and clamp it vertically during the curing process, this way all the glue will stay at the tip and around the threaded insert.
 I also use a rolled piece of sand paper to scratch the inside of the tube  and then clean it  thoroughly with alcohol.
Martin
Post by: Motorman on August 03, 2024, 03:02:26 PM
I alway thought of JB weld as being fairly thixotropic.
Post by: Colin McRae on August 03, 2024, 06:21:45 PM
Martin
I could see that happening if there was a significant gap between the threaded stud and the CF tube ID. The 3mm ID CF tube I have been using and a 4-40 threaded stud is a snug fit. If the JB epoxy is pooling at the bottom, I have not seen any ill effects. The pushrod ends have been plenty strong and adequate for the application.
Post by: Steve Helmick on August 08, 2024, 11:30:49 AM
On the other hand...if a guy is an expert class flier and expects to put 1,000 > 3,000 flights on his new plane...or if he's building planes for paying customers...attention to details and control system durability is mandatory*.  H^^ Steve
*Except of course, for the inexpensive ARF's. If the controls on those last for 10 flights, you're lucky.
