  • June 28, 2025, 03:44:57 PM
Author Topic: Carbon Fiber Push Rod  (Read 1094 times)
Offline Michael Massey
« on: March 10, 2014, 02:34:32 PM »
I am getting ready to retro fit a carbon fiber push rod into a heavy 60 size plane that I suspect, was experiencing  push rod flex with the older wire push rod.  What size (diameter) carbon fiber push rod should I be using?  Thanks.
Eagle Point, Oregon
AMA 914713
Re: Carbon Fiber Push Rod
« Reply #1 on: March 10, 2014, 03:13:50 PM »
I go to Eugene Toy & Hobby.  Visit the carbon fibre tubing display rack.  Grab some and test by flexing.  If it looks nice and stiff, I buy it.  I don't pay any attention to the size marked.
« Reply #2 on: March 10, 2014, 03:52:22 PM »
There's an archery shop about 15 miles from me that sells rebuildable arrows -- usually these are arrows that are missing the heads and some fletching, but have good shafts.  They go for a buck apiece.
Then I whack off the ends and use them for pushrods.  The one that's rolling around on my electronics bench is 7.5mm OD, 1mm wall thickness.
Offline Kim Doherty
« Reply #3 on: March 10, 2014, 08:38:40 PM »
Assuming the connections to the rod enter and exit in the center of the rod then you can use just about any wall thickness and diameter you can find. Some rather exceptional models have been flown with .020 wall .250 dia soft aluminum tube. You don't need much.
Kim.
Offline SteveMoon
    • www.ultrahobbyproducts.com
« Reply #4 on: March 12, 2014, 09:00:23 PM »
Michael: For .60 size planes I always use 3/16" cf pushrods with 4-40 inserts.
I've used the rods from Central Hobbies for years with great success. I also
ALWAYS use 24 hour J-B Weld to assemble them.
Tags: Push  Rod
