  • June 26, 2025, 04:16:57 PM
Author Topic: Carbon fiber props  (Read 3662 times)
Carbon fiber props
« on: April 12, 2014, 11:31:05 PM »
    Since Bolly carbon fiber props are not available who is making CF props? I would like to buy a few but don`t know where. I`m looking for 11 x 6 props for my OS.40 FP. All info appreciated,Thanks.
Offline Bootlegger
Re: Carbon fiber props
« Reply #1 on: April 13, 2014, 05:54:44 AM »
 Juan, we have been using 11x5 APC props on our FP and LA 40's with a lot of success, also 10.5 x 4.5 APC props.
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #2 on: April 13, 2014, 06:10:54 AM »
There are no carbon props in active production right now in our useful sizes.  Keep trying the classifieds to buy some or go APC route or wood.  A few are making some for their own needs.  Not sure how many carbon props were ever made with that much pitch.  They are mostly for piped engines that run higher RPM and pitches under 5" usually.
Offline Paul Wescott
« Reply #3 on: April 13, 2014, 07:23:23 AM »
How about:
www.aeroproduct.net or
www.eliminatorprops.com ?
They both have useful sizes listed.  Am I wrong?
Paul W.
« Reply #4 on: April 13, 2014, 09:22:06 AM »
Not sure about updated info on the sites.  Not aware of any recent manufacture although a few older stock props might be out there.  Bolly quit and Mejlik opted to only make props like 18" and bigger,  doing away with small production.  Brian Eather retired so......maybe somebody I don't know about.
Offline Brian Massey
    • California Car Clubs
« Reply #5 on: April 13, 2014, 12:22:11 PM »
Brian Eather makes some dang fine CF props  y1 y1 y1
Here's his latest (I think) list. email brianea@optusnet.com.au
Brian
AMA 55421
Madera, CA
Offline Igor Burger
« Reply #6 on: April 13, 2014, 01:03:24 PM »
Some people here use 3 blade carbon props 11"x5" on OS max .46 LA whivh we use on electric. I think it will work well for .40 shortened little bit.
Offline bob whitney
« Reply #7 on: April 13, 2014, 02:09:32 PM »
i have been making carbon props for glo and e stunt . i have a bolly copy narrow 12/6 that seems to work better than the APC 11/5. , have a rev-up 12x5 copy and 3 blades12x5  in glo and e  also a 12x4 E 3 blade
rad racer
« Reply #8 on: April 13, 2014, 02:18:32 PM »
What is wrong with the Eliminator and PA props?  Plenty available in all sizes.  You might check before you repeat again that nothing is available.  And Whitney has props available.
« Reply #9 on: April 13, 2014, 02:29:28 PM »
I exchanged emails with Brian Eather just a few weeks ago. He sent me his newest price list and did not indicate he was retiring. He did take a "leave of absence" about a year ago for some surgery.
Brian
AMA 55421
Madera, CA
« Reply #10 on: April 13, 2014, 02:41:22 PM »
Sorry to all.  I did say there might be someone I was not aware of.  Brian did make me a batch of props last fall but told  me he didn't make many anymore but would open his shop to make me (and someone else) some.  I simply took that as a favor but didn't get any impression he was going to produce again.  Glad that he is. The other you mentioned I've never heard of.
« Reply #11 on: April 13, 2014, 03:02:55 PM »
Sounds like I need to order quite a few, and quickly . . . just in case.
Brian
AMA 55421
Madera, CA
« Reply #12 on: April 13, 2014, 03:10:48 PM »
Brian
That was exactly my thought at the time so I ordered upwards of $400.00 worth then.  Wouldn't have worried about it if I'd have thought I could get more.  Could be Brian found out there was little supply out there so went back to work.
« Reply #13 on: April 13, 2014, 03:32:55 PM »
I have one of Bob's 12-6 very narrow props work good on ST/46
« Last Edit: April 13, 2014, 03:57:54 PM by Bill Little »
Offline 55chevr
« Reply #14 on: April 13, 2014, 03:37:25 PM »
Higher end Quad Copters ... the often disparaged Quad Copters, use pusher and tractor carbon fiber props ... I bought some 12x6-s ... good quality, not pricey.
Joe Daly
« Reply #15 on: April 13, 2014, 05:30:41 PM »
 Thanks for the wealth of reply`s,I have some homework to do because I would like props similar to the bolly. My engines work great with them. I have used the Zinger 11 X 5 with good results and at one time I had good runs with one Xoar 11 x 6 but once I broke that prop the other Xoar I had didn`t work as good. I have two Os.40 FP`s tuned differently and both worked well with the Bolly. Which of the other CF props you guys had luck with? Thanks again.
« Reply #16 on: April 13, 2014, 07:26:59 PM »
Juan;
If you can find one of Windy's videos about props, grab it; it is a wealth of information. They do a lot more than you might think.
Brian
AMA 55421
Madera, CA
