Regarding bearings, I'd plead the case for a sleeve bearing...a long one, maybe 1" long. <snip>
Brett Buck has written on this, and I've read what he's said and quietly agreed.
Yes, a long bearing is probably good, because the various pivots on a bellcrank are not all on one plane*. This means that when you exert force on the thing with the lines, and the elevator & flaps exert force via the pushrod, that the thing will tend to rock**. Having a long bearing on the bellcrank will keep it lined up with the pivot rod.
If I were going to make a bellcrank with ball bearings I would either use a pair of them on a carrier that spaces them out by at least an inch to control rocking, or I'd use a large-diameter (relatively) thin-section bearing, for the same reason. Here's a link to a thin-section bearing:
http://www.vxb.com/MR6702-Radial-Bore-Dia-15mm-OD-21mm-Width-4mm-p/mr6702.htm. Note that a pair of "normal" bearings makes a lot more sense to me than a thin-section bearing, but if you're determined, they're out there.
If you wanted to make a journal bearing with oilite or other bushings, you could make a long housing and only put bushings on the ends -- when rocking forces are present this is probably the only place that the bearings will really make contact anyway. That's getting too fancy for me -- I just use an aluminum journal riding on a drill rod or even a nice smooth piece of music wire, and I think it works just fine. Steve's idea of oiling the thing is probably a good one, and I may see if I can work that into my current project.
* Geometric plane. They're all on the same stunt plane.
** "Rock" as in "undesirable motion", not as in "man the way that works is really awesome, duuuuude".
