  • July 01, 2025, 02:59:49 AM
Author Topic: Canopy vacuum forming.  (Read 2186 times)
Offline jerry v
« on: September 10, 2021, 03:48:24 PM »
What material to use for sealing a canopy plug made from basswood? Temperature of the vacuum molding process is 400 - 450 degrees Fahrenheit. Clear plastic canopy shows the wood grain.
Jerry
Variety is the spice of life.
Offline Dan Berry
Re: Canopy vacuum forming.
« Reply #1 on: September 10, 2021, 04:14:30 PM »
Plaster of Paris will solve your problem.
Offline Roy DeCamara
« Reply #2 on: September 10, 2021, 04:31:15 PM »
Use polyester resin and sand with 320 and 400 girt sandpaper.  Usually 2 coats of resin will suffice with the final coat sanded with 400 grit.
« Reply #3 on: September 10, 2021, 05:18:18 PM »
  I have used several coats of dope, sanded and polished smooth between coats. When you get the grain filled, sand it and biff it like you would a dope finish. The same when using resin or epoxy. The plastic gets heated by the mold shouldn't be. When the plastic is applied to the mold the cool down is very rapid. I have also used hydrocal, a construction material much like plaster but much harder, to make a mold from an existing canopy. Clean the original canopy and wipe free of any dust. Spray in a light coat of PAM from the kitchen cabinet, then after mixing up some hydrocal and water to a pancake batter consistency, fill the canopy as far as needed.. You need to support the canopy securely during  this process. It takes about 30 minutes for it too set up completely, then I like to let it sit for 24 hours before using it. I have never had to seal a hydrocal mold.
Offline frank williams
« Reply #4 on: September 10, 2021, 06:44:12 PM »
If I remember correctly, Al Rabe said that he would pull one canopy and then use it as a surface for the part.  Then he would pull a second canopy over the first.  This second one would be the one used.  I seem to remember he was concerned, like you, with imperfections in the canopy mold.
Offline Dan Berry
« Reply #5 on: September 10, 2021, 06:54:58 PM »
Plaster of Paris is used as a filler. Sand it smooth, then seal it. It will stand up to the heat and pressure. It is easy enough to work with as a filler for the purpose.
Offline Gary Dowler
« Reply #6 on: September 10, 2021, 08:23:47 PM »
When I had the canopy made for my scale PT-26, I carved the plug from balsa, then applied and sanded off multiple coats of automotive sandable primer.  When I had it completely smooth, I applied pin striping tape to form the framework and sent it off.  the result was superb.  It was good enough that I was asked if it could be used for a new catalog offering.
Gary
Offline fred cesquim
    • Fred Cesquim Aeromodelos
« Reply #7 on: September 11, 2021, 06:01:39 AM »
Jerry
2 layers of thin CA sanded smooth with a final 1200 sandpaper run through would make it as an option
Offline Paul Wescott
« Reply #8 on: September 11, 2021, 08:33:58 PM »
Larry Renger told me that the pro’s at Mattel would make the wood plug a tiny bit undersize, then mold one sheet of plastic over the mold and leave it in place as described by Al Rabe via Frank’s post.  If Mattel could run production quantities in this fashion it must be a decent method.  Also seems like less work than sealing and sanding and such.
PW
Offline Curare
« Reply #9 on: September 13, 2021, 05:57:32 PM »
This is how I've done it for a while, carve your plug undersize, pull a canopy and LEAVE IT ON THE PLUG, zap it down if you have to, then sand with 600 till it's all matt, and pull another over the top, it'll be clean and clear.
Greg Kowalski
AUS 36694
Offline jerry v
« Reply #10 on: September 14, 2021, 06:19:11 AM »
Thanks for all replies!
I used dope to seal the wood, and first layer of thin plastic stays on the plug. This is Checkala Roma canopy, it was removable on the original. I was planning to have one layer of clear plastic as windows, and one layer on top of that as a cockpit “body” - clear or white, painted to the color, with windows frame/opening  cutouts. Plug has extra 1/4 in “skirt “, but front and back flat areas are made to size, with almost zero degrees draft, and they will be the part of the external structure. I was planning to use minimal internal structure in the canopy, because it’s a battery hatch. Layers of plastic make corners more and more round, and I would like to keep corners as sharp as possible.
I would like to post the Checkala Roma building tread here, I’m just not sure- in OTS or in the Building section.
Thanks again.
Jerry
Offline Warren Wagner
  • Bradenton, FL
« Reply #11 on: September 14, 2021, 09:35:46 AM »
Jerry,
As expected, the forum had viable solutions to your canopy issue.  Stunt Hanger is
a valuable resource.....thanks Sparky.
As far as posting is concerned, you might consider putting the 'build'
information in the "Building" sub forum, and including a link to the
"Old Time Stunt" sub forum.  I think that ideas picked up from your build,
would be exposed to more modelers if it is posted in the "Building" forum.
However, vise versa would work also, if you choose.
Thanks for sharing your project with us.
Cheers.
Warren Wagner
Clay, NY   AMA 1385
Warren Wagner
AMA 1385
Offline jerry v
« Reply #12 on: September 14, 2021, 12:22:55 PM »
Warren,
Thanks for your support! I will start the tread in the “Building “ section.
Jerry
Offline MikeyPratt
« Reply #13 on: September 25, 2021, 11:06:44 AM »
Roy is correct,
But it really depends on how intricate the finished canopy is.  I made more canopy’s than I care to think about for Sig production models and other people.  Basswood or pine worked best covered with polyester resin and sanded down super smooth.  The first pull should be a piece of .010 ABS and leave it on the wooden mold, then pull the next mold out of PPG clear.  If you want a defined canopy frame, make a hollow mold out of aluminum epoxy (Rein), add a plywood base with vacuumed holes and drill small holes (.015”) in the corners of the framing then when vacuumed formed the vacuum will pull the plastic into the corners around the canopy frame.  That gives the canopy an awesome professional look when finished.
Mike Pratt
