  • July 05, 2025, 08:01:34 PM
Author Topic: Epiphany  (Read 1997 times)
Offline Mike Griffin
Epiphany
« on: September 14, 2022, 03:33:20 PM »
Several years ago I built an Epiphany which was a kit by Pat Johnston.  I thought the wing design was beautiful.  I finished the model but it was destroyed in an accident before I ever got to fly it.  I ran across this picture of the wing as I was building it and the yellow on was Pat's if I remember correctly.
Offline Pat Johnston
Re: Epiphany
« Reply #1 on: September 14, 2022, 05:43:56 PM »
The Epiphany has proven to be a wonderful plane. So much so that I have made up designs that range in square inches from 202, 327 (twin), 402, 502, 557 ( single and twin), 617, and 710. The twin engine versions are a blast to fly.
Then there is the spinoff series from the 502. Now there are 12 “502” warbirds. The obvious next one was the Spitfire. Also, a Sea Fury, Mustang, P-40C, Wildcat, Hellcat, Bearcat, Bf-109, Fw-190, Ki-61 Tony, A6M Zero, and Yak-9. I built and flew the Fw-190, but after a few flights, an errant weed caught  the lines and the plane bit the dust. At least I had enough handle time to show the plane was a high performer and very easy to fly. Any one interested in any of these, feel free to contact me.
Pat Johnston
Idaho Skunk Works
Re: Epiphany
« Reply #2 on: September 14, 2022, 06:29:58 PM »
It is a beautiful design and Pat's kits are impeccable.  We live on a fixed income but once things get a little better, I will be ordering another Pat Johnston kit.  Thanks for all you do for our hobby Pat.
Online Mike Scholtes
Re: Epiphany
« Reply #3 on: September 14, 2022, 07:38:54 PM »
I have one of Pat's E-Twin 557s under construction. I can echo what Mike says, a beautiful model with a true elliptical wing. The only straight lines are the hinge lines. Even the root-to-tip taper is curved. There is a full-fuse version of this design now available. Outstanding wood selection and laser cutting, one of the finest kits I have ever seen. Will Hubin has developed a timer for this model for use with smaller and cheaper ESCs and motors.
Re: Epiphany
« Reply #4 on: September 14, 2022, 08:02:15 PM »
Beautiful work Mike.
Offline gene poremba
Re: Epiphany
« Reply #5 on: September 15, 2022, 03:23:35 AM »
 I really like the look of that wing Mike. Sorry to hear you didnt get to enjoy it in flight....Gene
Offline Dwayne Donnelly
Re: Epiphany
« Reply #6 on: September 15, 2022, 06:30:09 AM »
Please what size motors does it use?
Re: Epiphany
« Reply #7 on: September 15, 2022, 10:25:50 AM »
It uses two Cobra 2808-30 1000KV motors, paired with two Tempest 30-A 4S ESCs, all from Innov8tive Designs. As noted above Will Hubin has developed a timer that operates both motors and ESCs from a single timer. These are very inexpensive components and simple to program. The ESCs require a Tempest programmer, which is also simple and inexpensive.
Offline Paul Wescott
Re: Epiphany
« Reply #8 on: September 15, 2022, 01:53:32 PM »
Antone Kephart has one.  BEST flying plane in the club right now IMHO.
PW
Offline Bill Morell
Re: Epiphany
« Reply #9 on: September 16, 2022, 05:31:59 PM »
PW
I don't know about in the club but I've seen Antone fly his and it is a beautiful plane and flyer.
« Last Edit: September 19, 2022, 04:29:35 PM by Bill Morell »
Bill Morell
Vietnam 72-73
Offline Warren Walker
Re: Epiphany
« Reply #10 on: September 17, 2022, 06:50:53 PM »
I also have a twin under construction, they do fly very nice.
W.W.
Offline Stan Tyler
Re: Epiphany
« Reply #11 on: September 19, 2022, 02:36:28 PM »
I've also got a twin under construction. Thanks to Antone and Scott.
The elliptical wing is much easier to assemble that it appears. Pat did an outstanding job on the design.
Stan
Stan Tyler
AMA 3239
