  • June 17, 2025, 11:50:46 PM
Author Topic: NATS prep- competition is great but........  (Read 2986 times)
Offline Tom Luciano
« on: June 27, 2020, 10:00:15 AM »
the friendships in CL is the greatest part of the Hobby!
AMA 13001
Offline Tom Luciano
Re: NATS prep- competition is great but........
« Reply #1 on: June 27, 2020, 10:02:00 AM »
Yes im at Bubbas putting a new out board wing on my nats plane.
AMA 13001
Offline Tom Luciano
« Reply #2 on: June 27, 2020, 10:12:49 AM »
Thanks  to Frank and Bob
AMA 13001
Offline Tom Luciano
« Reply #3 on: June 27, 2020, 10:15:04 AM »
AMA 13001
Offline C.T. Schaefer
« Reply #4 on: June 27, 2020, 10:19:38 AM »
You got the A-Team on that one!!   TS
Offline Tom Luciano
« Reply #5 on: June 27, 2020, 10:21:44 AM »
Yes, TS!!
Reminds me of the story of Brett helping Bob put his Crossfire together.
AMA 13001
Offline Tom Luciano
« Reply #6 on: June 27, 2020, 12:53:56 PM »
Leaving  Bobs now 3pm Saturday. In 1 piece!
AMA 13001
« Reply #7 on: June 27, 2020, 01:05:24 PM »
Yes, TS!!
    This looks a lot more difficult, but you have less need to improvise. The deal at the NATs could have *easily* been done at the field and flown 10 minutes later.
    BTW, after having done *many* repairs kind of like this, might I suggest making a bunch of 1/16" balsa "diamonds", maybe 1/2" wide and 2.0 - 2 1/2" long, with the grain running the long way, and then cut through the sheeting to inset them into the wing across the joint. Cut around each diamond with your knife, pull up the sheeting, then glue the diamond into the foam with epoxy. This will create a bunch of low-angle splices to tie the two halves together. Let it set, sand it all off smooth, then refinish. Essentially every airplane I have has similar repairs, either from damage from handling/thermals, or stress failures.
Online Brent Williams
« Reply #8 on: June 27, 2020, 02:43:26 PM »
How did it shed the outboard panel like that?
Glad you are able to salvage the plane.
Offline Tom Luciano
« Reply #9 on: June 27, 2020, 02:45:41 PM »
Brett,
  Thats an excellent idea and i will do that! We also found a vertical  stress crack in the fuselage at the trailing edge i need to address.
BRENT
The culprit
AMA 13001
Offline Tom Luciano
« Reply #10 on: June 27, 2020, 02:50:07 PM »
Had my cones a bit too close to the circle. These are Heavy Duty DOT cones. They probably weigh around 20lbs a piece and are hard plastic.
AMA 13001
« Reply #11 on: June 27, 2020, 03:11:15 PM »
I've done that.
Offline Tom Luciano
« Reply #12 on: June 27, 2020, 03:17:42 PM »
Howard,
  Im feeling more and more like Im in good company! Almost as a baptism or right of passage. I need to fire up the autoclave to get'r dun!
AMA 13001
Offline Mike Haverly
« Reply #13 on: June 27, 2020, 03:42:26 PM »
Offline Joseph Daly
« Reply #14 on: June 27, 2020, 04:18:53 PM »
Tom,
I know the feeling! This is some year! I am a little further along then you. This happened a couple of weeks ago when it flamed out (instant discharged) pulling up in to a wing over and all I could do is watch.
Really sucks
Joe
« Reply #15 on: June 27, 2020, 04:22:08 PM »
I've done that.
   EVERYBODY has done that. Mine was my own fuel can, and, for extra credit, it was the *inboard* wing.
Offline Tom Luciano
« Reply #16 on: June 27, 2020, 04:50:25 PM »
Joe, Brett,
  Like i said im in good company. Bob said " you know you're never going to live this down." My only reply was "at least i didnt back over my plane!" Just saying!!
Joe sorry to hear but your repair is looking good!
Tom
AMA 13001
Offline Tom Luciano
« Reply #17 on: June 28, 2020, 03:37:43 AM »
Walt,
  Bob had some really good ideas on that. That is why he was the first guy I called Wednesday night when I hit the cone. Working late nights, he built a panel exactly the same as the orginal. We then had two shucks to work with. Using them to keep the panel plumb we were able to run the panel thru a bandsaw and get a exact cut. Little sanding in, and... .
  Im hoping to be in the air next weekend to get a week of practice before the Nats.  I got a lot of work to do!!!
# COne-vid nats 2020!
« Last Edit: June 28, 2020, 04:25:22 AM by Tom Luciano »
AMA 13001
Offline Frank Imbriaco
« Reply #18 on: June 28, 2020, 05:51:13 AM »
That's a pretty neat repair. I'd like to see how you got such a good glue joint.
Motorman 8)
Bob has had lots of practice- mostly with mishaps by others. Even to his own planes. Mostly, he's totally genius with this stuff.
Offline Blaine Buchtel
« Reply #19 on: June 28, 2020, 07:37:09 AM »
Bob Hunt’s craftsmanship and attention to detail are amazing.When I am faced with a new building problem I ask myself “ how would Bob H do this? He is in my opinion a true perfectionist and I’m always delighted to see his posts!
« Reply #20 on: June 28, 2020, 05:22:42 PM »
The only "collision" on my flying record was when I clipped a tree at Mike Hazel's "Zoot Ranch".  The tree got the worst of it.
Offline Tom Luciano
« Reply #21 on: June 29, 2020, 04:09:54 AM »
Im thinking this might be a good thread to keep going as it may help someone in the future.
We can also place wages on if, I'm going to get the thing done!!
Pictured are the diamond "stitches" that Brett suggested. They are staggered from top to bottom. I'm going to apply a very light coat of finishing resin to the new panel prior to final sanding to get the surfaces a bit more compatible in hardness as to not sand lows into the new panel. Hopefully to be applying veil tonight.
« Last Edit: June 29, 2020, 05:08:37 AM by Tom Luciano »
AMA 13001
Offline Tom Luciano
« Reply #22 on: June 29, 2020, 04:11:48 AM »
I will add a piece of fiberglass at the leading and trailing edge joints as well.
AMA 13001
Offline Tom Luciano
« Reply #23 on: June 29, 2020, 05:01:06 AM »
Blaine,
  I agree!
 Hoping a little rubs off!
I have to say, I have been blessed to be surrounded by a bunch of amazing modelers during my life.
Tom
AMA 13001
« Reply #24 on: June 30, 2020, 01:09:48 AM »
   I suppose that it is obvious, but, given the time available, you want to use some sort of two-part filler (SuperFil, or even Bondo), because you don't want anything that will shrink on you later.
Offline Steve Fitton
« Reply #25 on: June 30, 2020, 06:49:27 AM »
I had never realized a foam wing was repairable till seeing this thread....
Offline GERALD WIMMER
    • Auckland Free Flight Club
« Reply #26 on: June 30, 2020, 03:27:32 PM »
Hello
Its good to see Tom's nice model being resurrected with help from Bob's wing graft and I like Brett 's strengthening diamonds . Certainly proves with good workmanship and careful thought a lot of accidents can be repaired.
Regards Gerald
Offline Tom Luciano
« Reply #27 on: June 30, 2020, 05:37:43 PM »
Yea, im going to use super fil where needed. Some good news arrived today! Aircraft Spruce called on Friday that they were out of Insignia white. It showed  up today!  Have some coming from Brodak too!! Believe or not Wix was out of it as well! Well, i'll be well stocked with white dope
AMA 13001
Offline Tom Luciano
« Reply #28 on: June 30, 2020, 05:39:58 PM »
Getting close to seeing color. Maybe tomorrow  night!
AMA 13001
« Reply #29 on: June 30, 2020, 06:13:05 PM »
 Tommy:
Got toothpicks holding your eyes open wide due to lack of sleep ?
Tip weight box looks to be getting a second life.
Offline Tom Luciano
« Reply #30 on: July 01, 2020, 05:27:33 AM »
Tommy:
Head hit the pillow last night with the sun shining
Yes, probably took longer than making a new one but, the red stripe assured me I was putting it on the bottom of the wing!
...and here's the refinished product!
Bob
Yes, This plane was my inspiration! And still, looks great!
AMA 13001
Offline Tom Luciano
« Reply #31 on: July 03, 2020, 07:55:25 AM »
So I'm hoping to hit it hard this weekend with paint. In a little over 24hrs I managed to get my shop down to 38% humidity from 68%. I use a heater and dehumidifier.  These are the final repair shots before finishing. Figured I share the complete repair. Of course the traing edge fiberglass reinforcement falls right at the hinge! I gently sanded in approximately. 045 notch to accept the 2oz  cloth.
AMA 13001
Offline Tom Luciano
« Reply #32 on: July 03, 2020, 07:58:23 AM »
Last shot
AMA 13001
