General control line discussion => Open Forum => Topic started by: Paul Taylor on November 10, 2007, 02:49:23 PM
I am getting “Old Timers”.
I read some place a week or so about making adjustable lead outs using pop rivets, pictures and a very good how to.
I can not for the life of me remember where I saw it.
CLW, SN, on the dub-dub-dub.someplace.com??? ???
Anyone else seen that bit if info?
Paul H^^
Paul,
Look at the Tempest 40 wing I gave you. It uses eyelets inserted in the wingtip for adjustments.
:!It was on here a while back.You can find it in archives on building techniques I think.I read it and have been using the rivet thing eversince then.The plastic tube from wd40 cans etc. It works great. jim ( Page 6 building techniques by Bob Johnson a step by step)....jim
Page 7 Building Techniques by Bob Johnson for the adjustable lead outs page 6 for the adj. wing tip.
Willis
I think I know what you're talking about Paul..........I used lead outs like that on my Profile Mustang. Supposedly the pinch created by the slot on the pop rivet guide will hold it in place. I used drop of CA as insurance. y1
Try this. http://www.tulsacl.com/ajustleads.html
Paul; I've got it if you can't find it. Let me know. rog
I got it right from the horses mouth. (so to speak)
Thanks for the email Bob.
I have been using a similar method for years now, that I prefer. I use
a pin vise to hand drill holes in nylon 4-40 screws and then screw these
into the leadout holes. I tap the holes in the tap with a 4-40 tap, and
then soak them in CyA glue and retap them. This system works great,
and there is less chance of a nylon screw coming loose.
Later, Steve
Just finished printing off the great pictures of the adjustable leadouts. Looks a lot neater than I have ever done. I have also tried the one with the eyelets that push in and out for adjustment. But there are times you need a finer adjustment. Anyway they both work. Have fun, DOC Holliday
